Gapps on 4.3?
Discussion in 'Android' started by punk45rock, Apr 12, 2014.
  1. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    tried gapps-jb-20130812-signed.zip and gapps-jb-20130813-signed.zip from goo.im, gapps packages just force close when I try to run them. Has anyone had success with getting it to work?
    Edit: also tried paranoidandroid gapps for 4.3 but still had the same issue.
  2. mantonec
    mantonec New Member
    Apr 10, 2014
    gapps-jb-20130812-signed.zip works fine. no issue.
  3. eric
    eric New Member
    Nov 21, 2013
    26
    I'm having the issue of resizing not working. I did what worked before
    # e2fsck -f /dev/sdf5
    # resize2fs /dev/sdf5
    but it says the file system is already using all blocks. After going into gparted I see free space at the end of the drive, but I can't resize the partition at all.
    mantonec, what did you do different?
    Thanks
    Eric
  4. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    I will have to try again without resizing, I used gparted to extend the data partition to fill my micro SD card. I followed the same instructions from the gapps thread in this forum.
  5. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    I'm an idiot, was writing gapps to wrong partition. working well now.
