OpenEmbedded/Yocto for UDOO Boards
Discussion in 'Yocto' started by graugans, Nov 7, 2015.
  1. graugans
    graugans Administrator Staff Member
    Sep 17, 2015
    328
    141
    Andrea Rovai and Manuel Malagon like this.
  2. Manuel Malagon
    Manuel Malagon New Member
    Apr 29, 2016
  3. graugans
    Sep 17, 2015
    328
    141
    Login: root
    Password:
    There is no password needed
    Gesendet von meinem FP2 mit Tapatalk
    Manuel Malagon likes this.
  4. Manuel Malagon
    Apr 29, 2016
    Hey man thanks so much for helping. Now I'm able to play around with the board. Nevertheless I have another question.
    I would like to add some code into the u-boot. The reason that I need it into U-Boot is because I need that piece of code to be executed as soon as the board is plugged.
    So my question is, what should I do to add my code into the u-boot and then create the image again?
    Thanks!!
  5. graugans
    Sep 17, 2015
    328
    141
    What kind of code you want to add? Because u-boot has a powerful scripting engine
  6. Manuel Malagon
    Apr 29, 2016
    I need to add code to send some bytes to the LP5521 RGB LED driver chip. I have one that I have connected to the board and actually I'm currently using it from linux to indicate several statuses of my application but I need that the LED go RED as soon as I power the board and there is where u-boot enters the scene.
    Either by a u-boot script or C code is fine, I just have no idea what steps to follow to add this small piece of functionality to u-boot.
    Thanks!!
  7. graugans
    Sep 17, 2015
    328
    141
  8. graugans
    Sep 17, 2015
    328
    141
    modjo likes this.
  9. graugans
    Sep 17, 2015
    328
    141
    modjo likes this.
  10. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi all, i make a try this evening to program the sam3x on udoo quad with arduino ide (from external pc). I follow the tutorial here but arduino ide don't find the device (i removed the jumper J18 and identified the port com before :rolleyes:). After that i tested this : http://www.udoo.org/docs/Arduino_DUE_(Sam3x)/Troubleshooting_Programming_Arduino_Due_from_External_PC.html
    but i have this error when i try to program the card with arduino ide (1.6.9 and 1.6.5) :
    SAM-BA operation failed
    ERASE FLASH
    An idea ?
  11. graugans
    Sep 17, 2015
    328
    141
    This needs some investigation. UDOO Quad/Dual needs another tooling AFAIK something called bossac. And the arduino tooling may expects the UDOO to have a special IP or do you try over USB cable?
  12. graugans
    Sep 17, 2015
    328
    141
    Okay, looks like the Arduino GUI uses USB to serial in your case I'll check the schematic and try to find some time this afternoon to investigate it on my own.
    modjo likes this.
  13. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    This morning i'm trying on another pc (under kubuntu 14.10) and i have this message on arduino ide 1.6.9 :
    /home/mls/.arduino15/packages/UDOO/tools/bossac-udoo/1.3a-1.0/bossac-udoo: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /home/mls/.arduino15/packages/UDOO/tools/bossac-udoo/1.3a-1.0/bossac-udoo)
  14. graugans
    Sep 17, 2015
    328
    141
    Have you installed 32Bit libraries
  15. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    ...good question, i will check ...
  16. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    After a check; yes this package is already install :
    lib32z1 lib32ncurses5 lib32bz2-1.0
  17. graugans
    Sep 17, 2015
    328
    141
    After watching the match yesterday I found no time to test :(
  18. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Yes and sorry for that but we are in final :D
  19. graugans
    Sep 17, 2015
    328
    141
    Yeah, they forgot football is all about goals :)
  20. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi @graugans i have 2 anothers questions, i would like to add a ftp server on my image (for quad), i didn't find anything on it for the moment. Can you just confirm if i would like to add one i have just to add in my local.conf this for example :
    MACHINE_FEATURES_append = " \
    lvds7 \
    pure-ftpd \
    pure-ftpd is a part of meta-networking already use ...
    Another question, on my quad, i add a sata disk. I can saw it, mount it manually but if i would to mount it automatically at startup can you advise me a script or procedure please ?
    under a detail of my sdd :
    Disk /dev/sda: 232.9 GiB, 250059350016 bytes, 488397168 sectors
    Units: sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disklabel type: dos
    Disk identifier: 0x00096d0b
    Device Boot Start End Sectors Size Id Type
    /dev/sda1 2048 488390655 488388608 232.9G 83 Linux
