[SOLVED] Interaction between SAM3X8E and iMX6 processors
Discussion in 'UDOO QUAD' started by Arturo Lovera, Jun 27, 2016.
  1. Arturo Lovera
    Arturo Lovera New Member
    May 23, 2016
    Hi guys! i hope u r fine! i need to comunicate the processors SAM3X8E and iMX6.
    I use SAM3X8E to get data and iMX6 to process the data, i found the next script on the forum and internet:
    stty -F /dev/ttymxc3 cs8 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts
    My question is: How to use this script?
    i hope you understand my question
  2. Andrea Rovai
    Arturo Lovera likes this.
  3. waltervl
    And to read data from the SAM3X8E and process it on the iMX6 you can use the serial connection /dev/ttymxc3 between the 2 processors You better take a look at the Serial examples http://www.udoo.org/docs/Serial_Libraries/index.html how to process arduino data on the linux side with Python, C, PHP and Java
  4. Arturo Lovera
    May 23, 2016
    thank you guys! i have the comunnication between processors, do you have another example code?
  5. waltervl
  6. Arturo Lovera
    May 23, 2016
    @waltervl thank you so much for your support!!!
    waltervl likes this.
