Used Dual Board won't start..
Discussion in 'UDOO DUAL' started by veni, Jul 31, 2016.
Tags:
  1. veni
    veni New Member
    Jul 31, 2016
    Hi@all,
    I am new to udoo, have some experiences with Raw Arduino's (uno, micro), Rasperry PIs and working with Microcontrollers as a hobby since the 80c535 :)
    So I bought a used udoo dual board to see the capabilities as I like the concept.
    But...
    The first issue I got is that it boots only once successful from SD (two cards tested).
    I get a screen over hdmi and can use it with the linux system I downloaded from udoo site.
    But if I try a reboot I get only the short udoo screen and nothing more.
    Resets don't help, the short udoo screen here as well.
    If I wait a little time (15-30 Mins) the board is able to boot, but reboots don't work again.
    Looks to me like a temperature problem.
    The second issue, serial debugging isn't working.
    Windows 7/10 (on two computers tested) doesn't recongnize any new hardware on CN6 if I connect this port to the PC.
    J18 and J2 are set, J16 and J22 are open.
    Is the board maybe broken?
    Thanks
    Veni
    Perhaps something on the Arduino side (completely separate CPU) is preventing the linux side to reboot. Try to reset the Arduino side ( use the jumpers).
  3. waltervl
    veni and Andrea Rovai like this.
  4. veni
    veni New Member
    Jul 31, 2016
    Hi waltervl,
    thanks for your fast response.
    After reseting the arduino part (first shorten J16, second J22) the System reboots and starts as expected.
    Problem #1 solved, thanks :)
    J18, the one behind the "RST" button is set, still no new devices shown at PC site.
    Thx again
    Veni
  5. veni
    veni New Member
    Jul 31, 2016
    ...successfully uploaded "blink" from the internal Arduino IDE to the SAM Chip.
    This connection works, the LED "blinks".
    Veni
  6. waltervl
    Good news! I am not so familiar with the dual and have no idea why your pc is not recognizing the dual Usb. Perhaps it is as simple as trying another cable?
  7. veni
    veni New Member
    Jul 31, 2016
    You wrote it ;)
    Three cables tested, all not working :mad:
    Looks like USB cables only for charging Mobiles.
    I found another USB Cable at work which works perfectly :)
    --snipp--
    U-Boot 2015.10-00061-g68849f9 (Jan 08 2016 - 17:01:43 +0100)
    CPU: Freescale i.MX6DL rev1.1 at 792 MHz
    Reset cause: POR
    Board: UDOO DualLite
    DRAM: 1 GiB
    MMC: FSL_SDHC: 0
    *** Warning - bad CRC, using default environment
    auto-detected panel HDMI
    Display: HDMI (1024x768)
    In: serial
    Out: serial
    Err: serial
    Net: using phy at 6
    FEC [PRIME]
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc0 is current device
    reading uEnv.txt
    52 bytes read in 10 ms (4.9 KiB/s)
    --snipp--
    The CRC Message is a warning, no error, correct ?
    Many Many thanks
    Veni
    waltervl likes this.
  8. waltervl
    Always blame the hardware first :)
    Looks like normal warning. @Andrea Rovai ?
  9. Andrea Rovai
    veni likes this.
  10. veni
    veni New Member
    Jul 31, 2016
    ...will do.
    Many Thanks
