Can-Bus
Discussion in 'Kernels' started by yesombre, Feb 26, 2014.
  1. yesombre
    yesombre New Member
    Nov 20, 2013
    Hello Udoo Community,
    I'm currently trying to get the Can Bus working on the Udoo Quad. Has someone tried the same already?
    I have the current kernel sources from http://github.com/UDOOboard/Kernel_Unico and changed the following parts:
    arch/arm/mach-mx6/board-mx6_seco_UDOO.c:
    Line 140ff:
    /******************* CAN *******************/
    #define MX6_SECO_UDOO_CAN1_STBY               IMX_GPIO_NR(1, 2)
    #define MX6_SECO_UDOO_CAN1_EN                 IMX_GPIO_NR(1, 4)
    Line 1078ff:
    imx6q_add_flexcan0(&mx6q_sabrelite_flexcan0_pdata);
    arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h
    Line 369ff:
            //MX6Q_PAD_GPIO_7__GPIO_1_7,                                                            // can tx
                    MX6Q_PAD_GPIO_7__CAN1_TXCAN,
            //MX6Q_PAD_GPIO_8__GPIO_1_8,                                                            // can rx
                    MX6Q_PAD_GPIO_8__CAN1_RXCAN,
    Line471:
            //MX6Q_PAD_GPIO_8__GPIO_MODE,
            //MX6Q_PAD_GPIO_7__GPIO_MODE,
    But probably these are not all changes necessary, as its not working.
    Greets and thanks for any help,
    yesombre
  2. yesombre
    yesombre New Member
    Nov 20, 2013
    Seems like its working now. Haven't tried actual communication, but the device is opening.
    root@localhost:/home/udoo# ip link set can0 type can bitrate 125000
    root@localhost:/home/udoo# ipconfig can0 up
    root@localhost:/home/udoo# ifconfig
    can0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
              UP RUNNING NOARP  MTU:16  Metric:1
              RX packets:0 errors:0 dropped:0 overruns:0 frame:0
              TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:10
              RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
              Interrupt:142
    I will keep you posted if can communication is really working.
    Greets,
    yesombre
  3. jbtatou
    jbtatou New Member
    Jun 19, 2014
    Hi, have you some result about can communication?
    greets,
    Jb
  4. lukas
    lukas New Member
    Aug 1, 2014
    Hey, I would also be really interested in information about it! Was there any progress or verification?
  5. chrta
    chrta New Member
    Aug 5, 2014
    Hello yesombre,
    thanks for your post. CAN is working fine with the your changes. Below is the complete diff i used. I do not use any enable or standby pin, only the RX and TX pins.
    When connecting the CAN-Phy, i discovered a mistake in the schematic pin labels. According to the datasheet (and the kernel sources), GPIO_8 is FLEXCAN1_RX, but in the UDOO schematic the signal is labeled CANTX_IMX. But GPIO_8 must be connected to the R (Receiver output) pin of the Phy. GPIO_7 (FLEXCAN1_TX, and in the schematic CANRX_IMX) must be connected to the D (Driver input) pin of the CAN-Phy.
    Additionally the according pins of the arduino mcu must be configured as input pins, so they do not interfere.
    I use the yocto image from https://github.com/rongals/meta-ronga-udoo and added the following packages:
    IMAGE_INSTALL += " \
        canutils \
        iproute2 \
    iproute2 is needed to get a ip executable that supports CAN, ip from busybox does not support it.
    diff --git a/arch/arm/mach-mx6/board-mx6_seco_UDOO.c b/arch/arm/mach-mx6/board-mx6_seco_UDOO.c
    index 435a50d..942678a 100644
    --- a/arch/arm/mach-mx6/board-mx6_seco_UDOO.c
    +++ b/arch/arm/mach-mx6/board-mx6_seco_UDOO.c
    @@ -1060,7 +1060,7 @@ static void __init mx6_seco_UDOO_board_init(void)
     	imx_asrc_data.asrc_core_clk = clk_get(NULL, "asrc_clk");
     	imx_asrc_data.asrc_audio_clk = clk_get(NULL, "asrc_serial_clk");
     	imx6q_add_asrc(&imx_asrc_data);
    -      //  imx6q_add_flexcan0(&mx6q_sabrelite_flexcan0_pdata);
    +	imx6q_add_flexcan0(&mx6q_sabrelite_flexcan0_pdata);
     	/* release USB Hub reset */
     	gpio_set_value(MX6_UDOO_USB_HUB_RESET, 1);
    diff --git a/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h b/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h
    index bfd2c4b..9471b03 100644
    --- a/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h
    +++ b/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h
    @@ -366,10 +366,10 @@ static iomux_v3_cfg_t mx6qd_seco_UDOO_pads[] = {
     		// MX6Q_PAD_EIM_D24__UART3_TXD,
     		// MX6Q_PAD_EIM_D24__ECSPI1_SS2,
    -	MX6Q_PAD_GPIO_7__GPIO_1_7,								// can tx
    -		// MX6Q_PAD_GPIO_7__CAN1_TXCAN,
    -	MX6Q_PAD_GPIO_8__GPIO_1_8,								// can rx
    -		// MX6Q_PAD_GPIO_8__CAN1_RXCAN,
    +	//MX6Q_PAD_GPIO_7__GPIO_1_7,								// can tx
    +		MX6Q_PAD_GPIO_7__CAN1_TXCAN,
    +	//MX6Q_PAD_GPIO_8__GPIO_1_8,								// can rx
    +		MX6Q_PAD_GPIO_8__CAN1_RXCAN,
     static unsigned int mx6q_set_in_outputmode_low[] = {
    Regards,
    chrta
  6. xuio
    xuio New Member
    Nov 2, 2014
  7. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Great job ! It's very interesting to can use can on udoo ! But, what kind of PHY do you use ? Is-it possible for somebody to explain me how to modify the kernel to use it ? I never make this ...
  8. xuio
    xuio New Member
    Nov 2, 2014
    There are instructions on how to modify the kernel in this thread: can-bus-aka-flex-bus-t177.html
    I had no success compiling the kernel on the UDOO itself, so I used the freescale cross compiler toolchain from the downloads page.
    As transciever I am using the TI SN65HVD230D, note that the RX/TX lines are switched for the IMX6
    EDIT: I also have a ubuntu minimal image (14.04LTS) with CAN support available, I can upload it if someone is interested.
  9. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    I'd be interested in the general steps you took, to get a minimal Ubuntu 14.04LTS image up and running.
  10. serus
    serus New Member
    Nov 10, 2015
    can u post working image please ?
    i compile my own image with can support but nothing going out from board (tested by osciloscope)
