Hi, I'm following the doc to compile the u-boot for UDOO Quad in order to update the kernel to the last one. It seems that the configuration file in the doc is wrong. At this line: Code: make ARCH=arm CROSS_COMPILE=$TOOLCHAIN_PREFIX udoo_qdl_config I get: After a look at the configs directory, I found an other configuration file that works fine: Code: make ARCH=arm CROSS_COMPILE=$TOOLCHAIN_PREFIX udoo_qd_defconfig But after a few seconds, the kernel crash at boot. I tried with both the official kernel and the patrykk's kernel. Both crash at the same time. Any solution?
We've recently made some changes in the uboot, and eventually we may have broken something Let us look into it, fix the problem and I'll let you know
I still have the issue when building Yocto/OpenEmbedded for the UDOO Quad. The kernel crash after a while at boot. I don't know if it's related to U-Boot or the Kernel defconfig but this used to work.
Here is the output (the same as before) : http://paste.ofcode.org/k6JHFaWtuPWd74GfgNeN4R It crashes at line 170 and reboot automatically.
Hi there @cyrilf, your problem is related to the Uboot. Use this branch of the Uboot: https://github.com/UDOOboard/uboot-imx/tree/2015.10.fslc-qdl (@waltervl this is the thread I should have answered )
Well I see thanks. So now I should modify the Yocto project to use different branch depending on the target (udooneo or udooqdl).
The Yocto project doesnt' build anymore Here is the output : http://paste.ofcode.org/tPfbD6mXnuNbZMpjv3vq95
I removed the patch from the layer file and moved all the dtb files into a dts/ directory so now it compiles and boot. The patch should be updated.
