Compile kernel with SPI serial port support
Discussion in 'Kernels' started by Whatdoudoo, Jun 22, 2015.
  1. Whatdoudoo
    Whatdoudoo New Member
    Jun 22, 2015
    I have an UDOO Quad Rev.D and I would like to activate the serial port SPI2 in the kernel so I can use them from the i.mx6. I chose SPI2 because it is available on the header. I am not sure what I need to add to the kernel files to get it working. I have managed to compile the kernel and get the UARTS working, but I am clueless with the SPI interfaces. Has anyone been able to get a serial port working for the i.mx6? I guess if all else fails, I could bit bang it. Would be nice to get it working without having to bit bang though. Is there a driver for the SPI interface that is needed? Any help would be appreciated. I did find this link on freescale, so I am going to see what I can accomplish while I wait...
    https://community.freescale.com/thread/302612
    Thanks!
  2. Andrea Rovai
    Hi there Whatdoudoo,
    for the moment regarding this matter the best documentation is indeed the Freescale website.
    I suggest to go for the solution you provided and try if it works.
    Cheers
  3. Whatdoudoo
    Jun 22, 2015
    Ok, I will try it this week sometime don't have time today. I already changed the pins in board-mx6qd_seco_UDOO.h. Would the only other file I need to change be the board-mx6_seco_UDOO.c? And I also assume I would use the spidev driver as they did on the freescale link? Thanks!
  4. Andrea Rovai
    I believe the answer yes, give it a try and let us know.
  5. Whatdoudoo
    Jun 22, 2015
    I have tried both ESCPI1 and ESCPI2 with no luck. I finally found a link that said you have to enable the User mode support in the spi device section of the menu config which I have also done.
    Device Drivers --->
    [*] SPI support --->
    <*> Freescale i.MX SPI controllers
    <*> User mode SPI device driver support
    The thing is, I think there is suppose to be an SPIDEV controller in this section to use the spidev drivers. All that is there is the Freescale i.mx SPI Controllers and I haven't found any info on them yet. Speaking of that, I may just be able to add the define for that, have not tried that yet.
    I also found this link in which there was a bug on the raspberrypi which looks like the same problem I am having, so maybe that bug in this kernel as well.
    https://github.com/raspberrypi/linux/issues/296
    Anyway, I have not given up yet just hoping someone might be able to steer me further quicker. Here are my current files. I had no problem enabling all the uarts, but the SPI devices have been a real pain. Anyone see if I'm doing something wrong or something I'm not doing. If these files are right, the problem must be elsewhere.
    ########## board-mx6qd_seco_UDOO.h ##############
    //enabling SPI1, comment out GPIO and uncomment SCLK
    // MX6Q_PAD_DISP0_DAT20__GPIO_5_14, // pin 36
    MX6Q_PAD_DISP0_DAT20__ECSPI1_SCLK,
    //enabling SPI1, comment out GPIO and uncomment MOSI
    // MX6Q_PAD_DISP0_DAT21__GPIO_5_15, // pin 37
    MX6Q_PAD_DISP0_DAT21__ECSPI1_MOSI,
    //enabling SPI1, comment out GPIO and uncomment MISO
    //MX6Q_PAD_DISP0_DAT22__GPIO_5_16, // pin 45
    MX6Q_PAD_DISP0_DAT22__ECSPI1_MISO,
    //enabling SPI1, comment out GPIO and uncomment SP1 SSO
    //MX6Q_PAD_DISP0_DAT23__GPIO_5_17, // pin 46
    MX6Q_PAD_DISP0_DAT23__ECSPI1_SS0,
    ########## board-mx6_seco_UDOO.c ##############
    I added an SPI section.
    * SPI *
    // chip select pin
    static int mx6q_UDOO_spi_SS0[] = {
    // this struct is added in function mx6_seco_UDOO_board_init()
    static const struct spi_imx_master mx6q_UDOO_spi_data2 __initconst = {
    .chipselect = mx6q_UDOO_spi_SS0,
    .num_chipselect = ARRAY_SIZE(mx6q_UDOO_spi_SS0),
    // all spi devices initialization data goes in this array
    static struct spi_board_info imx6_UDOO_spi_any_device[] __initdata = {
    .modalias = "spidev",
    .max_speed_hz = 20000000, /* max spi clock (SCK) speed in HZ */
    .bus_num = 0,
    .chip_select = 0,
    .mode = SPI_MODE_0,
    // this is called in function mx6_seco_UDOO_board_init()
    static void spi_device_init(void) {
    imx6q_add_ecspi(0, &mx6q_UDOO_spi_data2);
    spi_register_board_info(imx6_UDOO_spi_any_device, ARRAY_SIZE(imx6_UDOO_spi_any_device));
    In mx6_seco_UDOO_board_init(void) I added
    spi_device_init();
  6. Whatdoudoo
    Jun 22, 2015
  7. cyrilf
    cyrilf Active Member
    Feb 19, 2015
    168
    47
  8. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
  9. cyrilf
    Feb 19, 2015
    168
    47
    This a DTS file for an other board. There is no chance to have the same addresses or iomux.
  10. vpeter
    Nov 29, 2014
    303
    62
    Seems you would like to get final solution already? I'm trying to help you but ......
    You just need to set correct pins (hint: check the schematic).
  11. cyrilf
    Feb 19, 2015
    168
    47
    I've in mind this :
    &ecspi2 {
        fsl,spi-num-chipselects = <2>;
        cs-gpios = <0>,<&gpio3 31 0>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_ecspi2_1>;
        status = "okay";
        spidev@0x00 {
            compatible = "spidev";
            spi-max-frequency = <20000000>;
            reg = <0>;
        spidev@0x01 {
            reg = <1>;
    &iomux {
            imx6q-udoo {
                  pinctrl_ecspi2_1: ecspi2grp-1 {
                        fsl,pins = <
                            MX6SL_PAD_ECSPI2_MISO__ECSPI2_MISO 0x100b1
                            MX6SL_PAD_ECSPI2_MOSI__ECSPI2_MOSI 0x100b1
                            MX6SL_PAD_ECSPI2_SCLK__ECSPI2_SCLK 0x100b1
                            MX6SL_PAD_ECSPI2_SS0__ECSPI2_SS0 0x100b1
                            MX6SL_PAD_KEY_ROW3__GPIO3_IO31 0x100b1
    Maybe I can guess the 2 GPIO for the chip select (cs-gpios) but I cannot figure out the rest.
  12. patrykk
    patrykk Member
    Dec 10, 2014
    52
  13. cyrilf
    Feb 19, 2015
    168
    47
    I pulled the last commits and compiled the kernel with the new DTS files.
    I do have the spidev1.0 and spidev1.1 devices in /dev now ! I'll try next week to start an SPI communication for test.
  14. terraceaudio
    terraceaudio New Member
    May 14, 2014
    I'm trying to accomplish the exact same thing. Can you let me know the steps you took for success?
    Cheers!
  15. cyrilf
    Feb 19, 2015
    168
    47
    Just clone the patrykk's repository. Configure and build your kernel.
