Configure ntp
Discussion in 'Yocto' started by modjo, Dec 29, 2016.
  1. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi, i would like to configure ntpd for my udoo quad (yocto krogoth) but i have some issues ...
    First, i have added ntpd in my local.conf, all build fine.
    Then, on the card try to configure it, under my ntp.conf
    server 0.fr.pool.ntp.org
    server 1.fr.pool.ntp.org
    server 2.fr.pool.ntp.org
    server 3.fr.pool.ntp.org
    relaunch ntpd but the date didn't update ?
    an exemple of ntpd -date :
    root@udooqdl:~# ntpd -date
    28 Dec 16:43:08 ntpd[521]: ntpd 4.2.8p8@1.3265 Fri Nov 25 14:27:27 UTC 2016 (2): Starting
    28 Dec 16:43:08 ntpd[521]: Command line: ntpd -date
    28 Dec 16:43:08 ntpd[521]: proto: precision = 3.000 usec (-18)
    28 Dec 16:43:08 ntpd[521]: command line trusted key e is invalid
    Finished Parsing!!
    move_fd: estimated max descriptors: 1024, initial socket boundary: 16
    28 Dec 16:43:08 ntpd[521]: Listen and drop on 0 v6wildcard [::]:123
    28 Dec 16:43:08 ntpd[521]: Listen and drop on 1 v4wildcard 0.0.0.0:123
    28 Dec 16:43:08 ntpd[521]: Listen normally on 2 lo 127.0.0.1:123
    restrict: op 1 addr 127.0.0.1 mask 255.255.255.255 mflags 00003000 flags 00000001
    28 Dec 16:43:08 ntpd[521]: Listen normally on 3 eth0 192.168.1.38:123
    restrict: op 1 addr 192.168.1.38 mask 255.255.255.255 mflags 00003000 flags 00000001
    28 Dec 16:43:08 ntpd[521]: Listen normally on 4 wlan0 192.168.1.31:123
    restrict: op 1 addr 192.168.1.31 mask 255.255.255.255 mflags 00003000 flags 00000001
    28 Dec 16:43:08 ntpd[521]: Listen normally on 5 lo [::1]:123
    restrict: op 1 addr ::1 mask ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff mflags 00003000 flags 00000001
    28 Dec 16:43:08 ntpd[521]: Listen normally on 6 eth0 [fe80::2c0:8ff:fe88:27f8%2]:123
    restrict: op 1 addr fe80::2c0:8ff:fe88:27f8%2 mask ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff mflags 00003000 flags 00000001
    28 Dec 16:43:08 ntpd[521]: Listen normally on 7 wlan0 [fe80::7edd:90ff:fe90:cec9%3]:123
    restrict: op 1 addr fe80::7edd:90ff:fe90:cec9%3 mask ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff mflags 00003000 flags 00000001
    28 Dec 16:43:08 ntpd[521]: Listening on routing socket on fd #24 for interface updates
    event at 0 0.0.0.0 c01d 0d kern kernel time sync enabled
    event at 0 0.0.0.0 c012 02 freq_set kernel 0.000 PPM
    event at 0 0.0.0.0 c011 01 freq_not_set
    event at 0 0.0.0.0 c016 06 restart
    sleep until 16:43:10 scheduled at 16:43:08 (>= 00:00:00)
    sleep until 16:43:14 scheduled at 16:43:10 (>= 00:00:00)
    sleep until 16:43:22 scheduled at 16:43:14 (>= 00:00:00)
    Normaly the date would be thursday 29 december 14:00:06
    An idea ?
  2. graugans
    Sep 17, 2015
    328
    141
  3. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Thanks, but it didn't help me.
    @cyrilf , i cry that you already configure ntpd, can you say me how you did it please ?
  4. cyrilf
    cyrilf Active Member
    Feb 19, 2015
    168
    47
    I simply added a *.bbappend file to specify the ntp.conf file I want to use.
    receipes-support/ntp/:
    • files/ntp.conf
    • ntp_%.bbappend
    ntp_%.bbappend
    FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
    # Add Red Hat NTP servers to synchronize the UDOO local date
    SRC_URI += "file://ntp.conf"
    do_install_append() {
       install -m 644 ${WORKDIR}/ntp.conf ${D}${sysconfdir}
    ntp.conf
    # This is the most basic ntp configuration file
    # The driftfile must remain in a place specific to this
    # machine - it records the machine specific clock error
    driftfile /var/lib/ntp/drift
    # This should be a server that is close (in IP terms)
    # to the machine.  Add other servers as required.
    # Unless you un-comment the line below ntpd will sync
    # only against the local system clock.
    # server time.server.example.com
    # Using local hardware clock as fallback
    # Disable this when using ntpd -q -g -x as ntpdate or it will sync to itself
    server 127.127.1.0
    # Red Hat time servers
    server 0.rhel.pool.ntp.org iburst
    server 1.rhel.pool.ntp.org iburst
    server 2.rhel.pool.ntp.org iburst
    server 3.rhel.pool.ntp.org iburst
    fudge 127.127.1.0 stratum 14
    # Defining a default security setting
    restrict default kod nomodify notrap nopeer noquery
    restrict -6 default kod nomodify notrap nopeer noquery
    restrict 127.0.0.1
    restrict -6 ::1
    modjo likes this.
  5. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    I will make a try and let you know.
    cyrilf likes this.
  6. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    it take a time but after adding your config ntp works :)
    edit : i just add it at
    at the top of the file to ignore the panic threshold.
    graugans likes this.
