Hello all! Simple question. Would it be possible to run linux mint(15-17) on the udoo quad. im assuming somehow it would be possible since mint is based on debian. Any ideas or suggestions would be greatly appreciated. Thanks much.
I have this version: http://www.linuxmint.com/edition.php?id=154 and I get a blank screen via HDMI, and nothing through the serial COM port (I know it's connected properly though since if I unplug my UDOO the window closes) Edit: After trying the official UDOObuntu to verify my UDOO works fine, I'm going to try this version (since it's 32-bit, and I'm pretty sure by now the UDOO requires 32-bit) and create a bootable SD as explained in the wiki.
I have a new X86 Advanced Plus out of the box, with 7" display module and WiFi. I built a Linux Mint 18 XFCE edition USB boot stick using Universal USB Installer https://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/ Note that I installed the 64-bit version. This installed perfectly. Easy connection to my wireless network. Easy updates. I have also installed CrossOver Linux from https://www.codeweavers.com/ Now running LabVIEW in a Linux environment! I have a USB-serial converter connected, and it operates as a Windows COM port. All very, very good - Thank you UDOO team!
