neo usb connection to PC interrupts its connection to Wifi
Discussion in 'UDOO NEO' started by Snoopy, Apr 20, 2017.
  1. Snoopy
    Snoopy New Member
    Apr 20, 2017
    when i connect my neo board and ubuntu boots up, a virtual ethernet connection is established with neo board. i can connect to neo via web control panel or VNC, but can't surf the web as long as the ethernet connection is enabled.
    Anyone experienced this problem or knows how to solve it?
    Help is much appreciated :)
  2. bremenpl
    bremenpl New Member
    Apr 16, 2017
    23
    I am experiencing thebsame issue in windows. Sharing my ethernet connection to the virtual gadget helped for some reason
    Wysłane z mojego MotoG3 przy użyciu Tapatalka
  3. waltervl
    waltervl Well-Known Member
    988
    299
  4. Snoopy
    Snoopy New Member
    Apr 20, 2017
    thanks for the tip. now i just have to get the bridge to work on Ubuntu
  5. Gorgo
    Gorgo Member
    Nov 9, 2016
    66
    Let me know if you find a solution :D
  6. Maurice
    Maurice Active Member
    Oct 13, 2015
    253
    48
    Which OS are you using? On Ubuntu I edited the routes of the network connection, constraining them to only the addresses on the Neo network.
  7. Gorgo
    Gorgo Member
    Nov 9, 2016
    66
    I'm using Elementary OS (based on Ubuntu 13.04). Tell me more how you fixed it.
    In my opinion it's a wrong UDOO's behaviour...
  8. Maurice
    Oct 13, 2015
    253
    48
    In the overview of network connections, select under 'ethernet' your UDOO Neo connection, choose 'Edit', go to IPv4, click Routes, select the two checkboxes (ignore automatic routes, use only for resources on the network). Same thing is there for IPv6.
    Maybe the UDOObuntu acts as if it is a network router? If you know how to fix it in UDOObuntu you could push it to the repo and it will be fixed for future versions.
