Open Media Vault - NAS Operating system
Discussion in 'Networking' started by mikelangeloz, Nov 14, 2013.
  1. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Open Media Vault
    OpenMediaVault is a free network-attached storage server, supporting CIFS (Samba), FTP, NFS, rsync, AFP protocols, S.M.A.R.T., local user authentication, and software RAID (0,1,5,6,10), with a web-based configuration interface. OpenMediaVault is currently distributed as an ISO image and in source form.
    OpenMediaVault was inspired by FreeNAS and other commercial NAS but is a complete new implementation. It is released under the GNU General Public License.
    Copyright Volker Thiele (thanks for this awesome work)
    Features
    Javascript/AJAX based WebGUI (based on ExtJS)
    Protocols: CIFS (via Samba), TFTP, FTP, NFS, SSH, rsync, AFP, UPnP, BitTorrent (protocol) and iTunes.
    Extensions (plug-ins) for: SlimServer, Xbox Media Stream Protocol.
    rsync server, client and local sync.
    File systems: XFS, JFS and ext2/ext3/ext4 are fully supported, NTFS read/write and FAT32 read/write supported.
    Hard drive: P-ATA/S-ATA, SCSI, iSCSI, USB and FireWire.
    GPT/EFI partitioning for hard drives larger than 2 Terabytes.
    Network cards: All wired and wireless cards supported by Debian.
    Boot from HDD, USB key, CompactFlash, CD-ROM + floppy disk, or USB flash.
    Hardware RAID cards: All those supported by Debian.
    Software RAID levels: 0, 1, 5, 6, JBOD, 5+0, 5+1, 0+1, 1+0, etc. (using mdadm).
    4KB sector formatting support for hard drives using Advanced Format
    S.M.A.R.T. support.
    Remote syslogd forwarding.
    SNMP monitoring.
    Email log and reporting notification.
    Link aggregation and link failover interface
    UPS (Uninterruptible power supply) support
    http://www.openmediavault.org/
    Made this image because I think this would be very useful to Udoo Users. With E-sata port, gigabit LAN, and all the power it has, think this will be a perfect solution to build an homemade NAS. The image is built on the same minimal ARMhf image and the kernel has the latest load average fix.
    This comes with some plugins already installed:
    Transmission BitTorrent
    ClamAV AntiVirus
    Apple Filling
    MiniDLNA DLNA Server
    Autoshutdown
    OpenVPN
    DNS and DHCP Server
    CREDENTIALS:
    SSH
    USER: root
    PASSWORD: openmediavault
    WEBUI:
    USER: admin
    Download link:
    UDOO QUAD:
    http://sourceforge.net/projects/min...ia Vault Udoo/Quad/OMV_Udoo_Quad.zip/download
    UDOO DUAL:
    yet to come
    Donate to the project if you like this system. Support open source devs!
    SCREENSHOTS:
    [​IMG]
    [​IMG]
    [​IMG]
  2. DracoLlasa
    DracoLlasa Member
    Oct 15, 2013
    407
    very nice.. thank you for sharing this
  3. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Yes, very useful.
    Have already had one person asking about this sort of thing on IRC and was able to point them at this thread. Very useful, and is a great addition.
  4. delba
    delba Administrator
    1,060
    Yep! Thanks mikelangeloz ;)
  5. dottore
    dottore New Member
    Nov 29, 2013
    This is exactly what I wanted, thank you. Only one thing missing for me - can't mount NTFS usb hard drive. Every time I'm stuck with following error message
    FATAL: Module fuse not found.
    As I understand it, used kernel is without fuse module and I should be able to compile kernel with fuse module but sadly I can't figure out how. Would be someone who was successful with this matter please kind enough to share how to make NTFS work?
  6. udoo_juergens
    udoo_juergens New Member
    Dec 27, 2013
    Thank you mikelangeloz for the interesting post.
    I have similar problem like dottore had with the OMV image: I can't mount NTFS SATA hard drives with this image. It seems to be a general problem, that has something to do with unsupported proprietary NTFS drivers. I had the same issue with ubuntu 12.04 image for udoo and for an "older" hardware (Time Slice). Though with Debian 7 wheezy armhf http://www.udoo.org/forum/viewtopic.php?f=19&t=576 it was possible to mount NTFS hard drives at udoo.
    After some research on how to install OMV to an existing Debian armhf, there seems to be no such activities in this direction (check http://www.udoo.org/forum/viewtopic.php?f=23&t=590).
    There is an installation guide for RPi (http://forums.openmediavault.org/viewtopic.php?f=12&t=481) which seems to be not fully applicable to the udoo. I could install OVM but could not start the WebGUI and only got an "500 internal server error".
    So far my results up to now, maybe this will help others with their attempts.
  7. rafalsw
    rafalsw New Member
    Dec 13, 2013
    Hi
    I tried to install OMV in accordance with the instructions for RPI (thanks udoo_juergens).
    The same problem and got an "500 internal server error".
    In the file / var/log/apache2/openmediavault-webgui_error.log i can see this:
    (104) Connection reset by peer: mod_fcgid: error reading data from FastCGI server
    [error] Premature end of script headers: index.php
    I have not found a solution yet.
  8. rafalsw
    rafalsw New Member
    Dec 13, 2013
    Hi.
    I added one file /etc/default/locale ("touch locale) and everything is ok.
    Regards
  9. udoo_juergens
    Dec 27, 2013
    @ rafalsw: You just added a file /etc/default/locale and now it works? I tried the same and restarted Apache but still only got error 500.
  10. rafalsw
    rafalsw New Member
    Dec 13, 2013
    Yes. Try dpkg-reconfigure locales maybe and watch file: /var/log/apache2/error.log (tail -f /var/log/apache2/error.log) when you try to open OMV.
    You can also check if the file /var/www/openmediavault/index.php starts up correctly:
    cd /var/www/openmediavault/
    php-cgi index.php
    In no errors, apache is the problem.
    Tomorrow i will try install everything again, from scratch, maybe I did something else I forgot :)
  11. udoo_juergens
    Dec 27, 2013
    Thanks rafalsw for the hints.
    I checked tail -f /var/log/apache2/error.log and got the error "suexec policy violation: see suexec log for more details" when I tried to open OMV. I couldn't find a solution for that error in the internet, so I removed apache2-suexec (apt-get remove apache2-suexec) and reinstalled again. Now I can access the OMV WebGUI.
  12. rafalsw
    rafalsw New Member
    Dec 13, 2013
    When I checked "/var/log/apache2/error.log" i got the error "php-fcgi: 26: .: Can't open /etc/default/locale" only.
    Regards
  13. udoo_juergens
    Dec 27, 2013
    Now I'm getting the next error: When I go to System -> Plugins I get the error:
    Failed to execute command 'export LANG=C;sudo dpkg-query --list 'openmediavault-*'':
    Error #4000:
    exception 'OMVException' with message 'Failed to execute command 'export LANG=C;sudo dpkg-query --list 'openmediavault-*'': ' in /var/www/openmediavault/rpc/plugin.inc:186
    Stack trace:
    #0 [internal function]: PluginRpc->getList(Array)
    #1 /usr/share/php/openmediavault/rpc.inc(265): call_user_func_array(Array, Array)
    #2 /usr/share/php/openmediavault/rpc.inc(98): OMVRpc::exec('Plugin', 'getList', Array)
    #3 /var/www/openmediavault/rpc.php(44): OMVJsonRpcServer->handle()
    #4 {main}
    I followed the instructions below from http://phpbb.openmediavault.org/vie...sid=bda449156eabf1746d2c2e7433da64fb&start=40 without success. Still get the same error message.
    1) root from the command line:
    mkdir /var/lib/dpkg/updates
    chmod 755 /var/lib/dpkg/updates
    mkdir -p /var/lib/php5
    chmod 1777 /var/lib/php5
    apt-get update
    2) reboot OMV
  14. rafalsw
    rafalsw New Member
    Dec 13, 2013
    Try to install openmediavault-omvpluginsorg package (apt-get install openmediavault-omvpluginsorg). For me it's works.
  15. udoo_juergens
    Dec 27, 2013
    Thanks again rafalsw. That works for me too.
    Regards
  16. Robandstuff
    Robandstuff New Member
    Jan 11, 2014
    What is he status of this with the Dual model? I was gifted one and would like to use it for a NAS/plex server. Also, what is the size requirement for this OS, 8gb like the standard Udoo distro? Thanks!
  17. lostfly
    lostfly New Member
    Dec 27, 2013
    11
  18. pandalust
    pandalust New Member
    Nov 6, 2013
    Hi, all!
    Just wanted to ask what was the transfer speeds you guys are seeing when using samba?
    Im getting about 1MB/s up which seems rather low, although I am using USB drives instead of the sata connection (mind you this drive goes at 28MB/s locally)
    Otherwise, cheers and thanks a lot for your effort!
  19. Robandstuff
    Jan 11, 2014
    Fails to boot/blank screens for me as well (on a Udoo Dual). I don't have a ton of experience with Linux. Anyone have any guidance on how to set this up starting from one of the stock images?
  20. valmanza83
    valmanza83 New Member
    Oct 28, 2013
    I have a question about the tutorial. There is no mention of where to get the sata power cable used. My question is where can i get the sata power cable in question? or more specifically where can i get the molex female connector?
    As well has anyone else noticed that the sata power cable they sell in the starter kit isn't the same in the tutorial?
