Powering UDOO from batteries
Discussion in 'General Discussion' started by Lifeboat_Jim, Nov 4, 2013.
  1. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    There seem to be quite a few battery related questions popping up at random.
    There are many different battery technologies, each with their pros and cons/characteristics - such as: power density, weight, cost, Depth Of Discharge, Safe Rate of Charge, Safe Rate of Discharge, Self Discharge Rate, number of charge cycles etc.
    If anyone has any questions, battery related, ask here and we'll sort you out as best we can with answers/advice.
    Remember if you ask a question, please specify your requirements/scenario (EG a Flooded Lead Acid battery is good, but would weight several times your robot so wouldn't be appropriate even if it meets all other criteria).
    Note: Some battery technologies can be dangerous if not treated with respect (such as LiPo). Don't do anything silly!
    Anyone interested in batteries for their UDOO will no doubt be interested in reading Draco's UDOO Power Consumption & UDOO Thermal Testing
  2. kintera
    kintera New Member
    Oct 28, 2013
    18
    Personally I prefer LiFePo4 cells over LiPo they are little more stable the LiOn or LiPo. Also please keep in mind with batteries Discharge Curve
    [​IMG]
    This site has a lot of good info on batteries. http://www.mpoweruk.com/performance.htm. Also http://www.batteryspace.com/ Is a good place to get LiFePo4 cells most can be purchase with over discharge protection (needed to keep from damaging the cells.) If you have questions on batteries I will attempt to answer any battery questions. I work with batteries on a daily basis.
  3. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    There are also some commercial power bank style portable LiPo batteries that have 9v DC Outputs
    Here is one i have used with my UDOO
    http://www.amazon.com/EZOPower-15000Mah ... B00DJG18IA
    This one is a smaller capacity but comes with a lot of extras.
    http://www.amazon.com/EZOPower-High-cap ... 005XQSN9G/
    I have started some capacity testing on a lot of my batteries but haven't completed testing on this one. Preliminary show it on mar with most similiar types, and its nice to have the 5v USB and 9v/12v output
  4. HixVAC
    HixVAC New Member
    Oct 25, 2013
    13
  5. ashtonkase
    ashtonkase New Member
    Jan 7, 2016
    I used a 9v battery on my udoo and now the usb doesn't work which renders the board useless as I cannot us it for serial communication.my board is a udoo neo
  6. Mathew Hoets
    Mathew Hoets UDOOer
    Sep 14, 2016
    Hi all,
    I'm using an x86 that I want to use as a car pc... essentially what I'm intending is to run it on the car battery with a regulator so the voltage remains consistent.
    What I want to find out though, is there a way I can get the board to auto boot/suspend/shut down based on an input from acc?
    Cheers
