problem with port /dev/ttymxc3
Discussion in 'General Programming Discussion' started by theravech, May 27, 2014.
  1. theravech
    theravech New Member
    Feb 4, 2014
    Hi friends,
    I'm working on a relay control via web and am experiencing some problems with our udoo.
    PHP simply does not recognize the door / dev/ttymxc3 that the fopen command.
    me no access to the relay when I try to test the page.
    I test it directly on the Arduino serial monitor my code works perfectly.
    I did tests with Windows using COM port and it works too!
    I'll post the code here so they can take a look and maybe they find a course for my situation.
    Arduino
    PHP/HTML
    I hope you can help!
    Leandro
  2. extream96
    extream96 New Member
    Jun 27, 2014
    48
    The problem could be that you don't have permission for the /dev/ttymxc3, you can use the command chmod 777 /dev/ttymxc3 and retry to connect via php.
    if you want use more settings there is a php library to set up the serial, it works correctly.
  3. francescomm
    francescomm Member
    Dec 14, 2013
    80
    Yes, I had the same problem with PHP, setting up permissions on the serial solved it
    sudo chmod 777 /dev/ttymxc3
  4. theravech
    Feb 4, 2014
    Perfect! tank you!!!
  5. ANA
    ANA New Member
    Aug 25, 2015
    Hi Everyone,
    I´m new on this and need some help about a Project that I´m working.
    I´m working with a ULTRASONIC sensor and I can´t communicate with PD.
    I´m using the Patch "Smart Theremin" :
    I don´t understand how to fix with PHP... I´m new in this,,,
    Someone can help me Please?
    There is the error on PD:
    [comport] opening serial port 0 failed!
    Opening /dev/ttymxc3
    [comport]: could not open device /dev/ttymxc3:
    failure(3) ERROR_PATH_NOT_FOUND
    The arduino patch show the comport 3, I try to change to comport 3 on PD and doesn´t work...
    Thanks
    Ana
