PWM PINS Problem
Discussion in 'UDOO NEO' started by Berk, Apr 14, 2017.
  1. Berk
    Berk New Member
    Nov 22, 2016
    17
    I have a problem with accessing PWM pins. I managed them as PWM2 and PWM5 from Device Tree Editor. But, I can not reach them from udoo terminal. I wrote:
    sudo sh -c "echo 0 > /sys/class/pwm/pwmchip0/export"
    Then, I took from terminal "I/0 Error". How can ı fix this problem ?
    Thank you.
    I am not sure but pwm_2 could be exported with echo 1 > /sys/class/pwm/pwmchip0/export
    This would result in a pwm1 in /sys/class/pwm/pwmchip0
    But it could also be 2 instead of 1 resulting in pwm2. Depends how the count is done.
  3. Berk
    Berk New Member
    Nov 22, 2016
    17
    I just have tried, but I got same result. I will try to manage PWMs from IDE. It may work. Thanks for your response walter.
  4. waltervl
    Are you sure you did a reboot after using the device tree editor?
  5. Berk
    Berk New Member
    Nov 22, 2016
    17
    Yes, I am sure. I rebooted every time after I used it. Firstly I tried it in default positions of pins, that time terminal showed to me no such files or directory. Then I fixed it logically, but I can not handle it with I/O error :(
  6. waltervl
    I just tried it and I was able to create pwm0 ( pwm_2) with
    And I got a working flashing led following the pwm instructions.
  7. Berk
    Berk New Member
    Nov 22, 2016
    17
    Do you think I should boot my device ? I will start everything simply :)
