Relay
Discussion in 'General Discussion' started by Deo Joseph, Apr 1, 2017.
  1. Deo Joseph
    Deo Joseph New Member
    Mar 31, 2017
    15
    Hi..
    i would like to control electrical appliances like fluorescent lamps (inductive load).
    Anyone please suggest me which relay should i use?
    Requirements:
    DC controlled relay(5-12V), AC switching(230VAC/20A)
    I need a industry standard highly reliable Electromagnetic relay..
  2. sirrab
    sirrab Member
    Jul 26, 2014
    193
    15
    Solid state relay might be a good choice for inductive loads. www.digi-key.com has a nice user interface for selecting electronic components.
  3. Deo Joseph
    Mar 31, 2017
    15
    solid state relays do have some limitations. so i am searching for electromagnetic relay..what if i make use of the following relay
    G7L-1A-TUB-J-CB-DC12
  4. sirrab
    sirrab Member
    Jul 26, 2014
    193
    15
    158ma coil current will need driver transistor.
  5. Deo Joseph
    Mar 31, 2017
    15
    ya for that..what if i use TPL7407L as a relay driver?
  6. sirrab
    sirrab Member
    Jul 26, 2014
    193
    15
    Yes, if you were driving 7 relays!
  7. Deo Joseph
    Mar 31, 2017
    15
    ok.. thank you for all your valuable inputs!
  8. Deo Joseph
    Mar 31, 2017
    15
    hi everyone..
    i need a power supply to drive relay coil (12V DC).
    i am planning for dual output power supply with 5V and 12V dc output so that i can power up both UDOO and Relay.
    What should be the current rating of the supply?
  9. sirrab
    sirrab Member
    Jul 26, 2014
    193
    15
    A single general purpose transistor would be simple and cheaper.
  10. Deo Joseph
    Mar 31, 2017
    15
    ok
    what if i am powering up 48 relays each with supply voltage of 12v dc and 160mA current.
    then what should be the power supply rating?
  11. sirrab
    sirrab Member
    Jul 26, 2014
    193
    15
    48 relays times 160ma, plus some extra for consistent operation. Which equals 7.68 Amps, plus some extra. So 10-15 Amp 12v supply. Are you going to switch every relay at once? Probably not. Are you going to use latching relays? If you do, you'll reduce static current draw. Which would ease the current requirements.
  12. Deo Joseph
    Mar 31, 2017
    15
    Hi Sirrab..
    Yes! only few relays will be ON at once (Rarely all) . What is the difference between Latching and non latching relay which one will be better for switching AC Lamps?
  13. sirrab
    sirrab Member
    Jul 26, 2014
    193
    15
    Either one will work for lamps. Latching relays take a pulse to switch, the other you have to keep the relay energized when switched.
  14. Deo Joseph
    Mar 31, 2017
    15
  15. Laura
    Laura Active Member
    Apr 22, 2016
    182
    80
    @Deo Joseph You will learn more by researching that information by yourself. All the dimensions are listed on the datasheet (available from that Mouser page you linked to). As you will need to mount the relays, I suggest you use a program like KiCad, and then use the footprint you created to place them along with the required PCB traces. An alternative to creating the footprint yourself, is to download the CAD file for the relay, which might possibly be found on the following page - http://www.omron.com/ecb/support/download/ry.html
  16. Deo Joseph
    Mar 31, 2017
    15
  17. Deo Joseph
    Mar 31, 2017
    15
    hi..
    which are the electromechanical relays suitable for controlling the fluorescent lamp with electronic ballast???
