rs485 on arduino/linux @ UDOO
Discussion in 'General Discussion' started by krapazok, Jul 12, 2014.
  1. krapazok
    krapazok New Member
    Jul 12, 2014
    Hello !
    (sorry for the bad whriting, i'm belgian :mrgreen: )
    hi have a short ask for you, i have a domotic project and i need to communicate on rs485 bus.
    It is possible to using arduino program with rx/tx rs485 AND using this same port with linux ?
    or i'm obligated to using one interface for the arduino AND one interface (usb) for the linux ?
    Thank you !
  2. xwalter
    xwalter Member
    Sep 8, 2014
    89
    There are several little board for the RS485 use
    Anyway you can build your board using a MAX485 or chip similary
    In this case the communication is hal duplex, it means you have a master for example arduino and other devices are slaves.
    You have to connect the chip at rx and tx pins of arduino and use an other bit for the direction , pin direction=1 is to send and pin direction=0 to receive .
