Schematic Diagram for UDOO
Discussion in 'General Discussion' started by E.Ghost, Nov 30, 2013.
  1. E.Ghost
    E.Ghost New Member
    Nov 30, 2013
    Hello,
    This is my first post, I got my UDOO Quad last week,
    I want to ask about the schematic diagram for UDOO Quad with pins functions.
    like the picture in attached files but without pins function.
    And please tell me which program UDOO team to draw Schematics or from where pick components
    Cheers,
    [​IMG]
    [​IMG]
  2. delba
    delba Administrator
    1,060
  3. E.Ghost
    E.Ghost New Member
    Nov 30, 2013
    Hi Mr.Delba
    all the schematics with no colors @ Corel Draw.
    BTW, this is the first time I use Corel Draw.
    I hope you add UDOO boards to Fritzing.
    also, I have many questions about UDOO cables and tutorials.
    I'll post it soon.
    Thanx
  4. DracoLlasa
    DracoLlasa Member
    Oct 15, 2013
    407
    i too would really like to see some fritzing objects for UDOO in the future..
  5. delba
    delba Administrator
    1,060
    k i'll forward your requests and see what we can do about it ;)
  6. Rob Napier
    Rob Napier New Member
    Aug 25, 2013
    Hi!
    I am working through the schematics in detail. I've found a few issues so far. Though I just discovered a change since I first obtained a copy. So I assume there has been an update.
    Is the published set of schematics error-free? If not, is it possible that these could be published?
    What is the model number of the i.MX6Q?
    And if this is not the right forum for these sorts of questions, what is?
    Finally, I've converted the files to Adobe Illustrator. I had to do it because all text appears as check boxes in Adobe applications. I'll share them once I have finished tidying them up and confirming their accuracy.
    Cheers!
  7. delba
    delba Administrator
    1,060
    Hi rob,
    of course the last schematics we uploaded are error-free. Go ahead and download it.
    Thanks for the converted files, i'm sure they'll be very useful for our community.
    About the model number of the i.MX6Q, i'll let you know asap.
    Best regards
  8. allwet
    allwet New Member
    Oct 30, 2013
    22
    I need the UDOO/Quad schematic (preferably in pdf format) so that I can troubleshoot my dead power supply on one of my two units. I can't find the schematic via this forum. The link in post #2 above does not have any schematics (http://www.udoo.org/forum/threads/schematic-diagram-for-udoo.477/#post-3939).
    My problem occurred after reviving my two quads which are similar in accessories. The second one does not have a display, but showed signs of degrading power when I tried to implement the wifi, no connectivity. Then the system died. I started disconnecting accessories, one at a time and the system would come up for a bit until the next failed reboot, until finally it won't come up at all. I swapped accessories between the two UDOOs and still the problem was central to the same UDOO unit. Conclusions so far are the on-board 12v power supply has had a slow death. I need the schematics for further investigation. Accessories: UDOO case fan, usb keyboard and mouse through a usb hub, then my Crucial 120GB 2.5" SSD (fits nicely under the board in the UDOO case kit. The other unit has same accessories + the 15.6 LVDS Touch Screen LCD display recently acquired. That system has no problems with power. Oh, I forgot, I even swapped the 12v power supply modules between units with no success. Good UDOO works fine with the bad unit's accessories.
  9. waltervl
    waltervl Well-Known Member
    905
    283
  10. allwet
    allwet New Member
    Oct 30, 2013
    22
    Finally found the schematic, but had to search the web to get it when it should have a path via the forum or UDOO product pages.
    I still have the problems yet to be resolved.
  11. allwet
    allwet New Member
    Oct 30, 2013
    22
  12. Laura
    Laura Active Member
    Apr 22, 2016
    129
    63
