[SOLVED] Bluetooth Dongle working...?
Discussion in 'General Discussion' started by HixVAC, Oct 26, 2013.
  1. HixVAC
    HixVAC New Member
    Oct 25, 2013
    13
    Anyone get the BT dongle working with Ubuntu? Trying to figure out if I'm failing at life and it's my fault I can't get it workin or if my BT dongle is defective.
    Thanks guys!
  2. saidol
    saidol New Member
    Oct 3, 2013
    24
    [SOLVED] Re: Bluetooth Dongle working...?
    you can activate BT usb dongle support following next two steps:
    step 1 - install bluez:
        • apt-get update
        • apt-get install bluez
    step 2 - Because of a ubuntu bug in bluez package, it miss startup script.
    So create a new file /etc/init.d/bluetooth and cut&past inside it the following code:
    #! /bin/sh
    ### BEGIN INIT INFO
    # Provides: bluetooth
    # Required-Start:    $local_fs $syslog $remote_fs dbus
    # Required-Stop:     $local_fs $syslog $remote_fs
    # Default-Start:     2 3 4 5
    # Default-Stop:      0 1 6
    # Short-Description: Start bluetooth daemons
    ### END INIT INFO
    # bluez    Bluetooth subsystem starting and stopping
    # originally from bluez's scripts/bluetooth.init
    # Edd Dumbill <ejad@debian.org>
    # LSB 3.0 compilance and enhancements by Filippo Giunchedi <filippo@debian.org>
    # Updated for bluez 4.7 by Mario Limonciello <mario_limonciello@dell.com>
    # Note: older daemons like dund pand hidd are now shipped inside the
    # bluez-compat package
    PATH=/sbin:/bin:/usr/sbin:/usr/bin
    DESC=bluetooth
    DAEMON=/usr/sbin/bluetoothd
    HCIATTACH=/usr/sbin/hciattach
    HID2HCI_ENABLED=1
    HID2HCI_UNDO=1
    UART_CONF=/etc/bluetooth/uart
    RFCOMM_NAME=rfcomm
    RFCOMM=/usr/bin/$RFCOMM_NAME
    RFCOMM_CONF=/etc/bluetooth/$RFCOMM_NAME.conf
    SDPTOOL=/usr/bin/sdptool
    SSD_OPTIONS="--oknodo --quiet --exec $DAEMON"
    test -f $DAEMON || exit 0
    # FIXME: any of the sourced files may fail if/with syntax errors
    test -f /etc/default/bluetooth && . /etc/default/bluetooth
    test -f /etc/default/rcS && . /etc/default/rcS
    . /lib/lsb/init-functions
    set -e
    # FIXME: this function is possibly a no-op
    run_sdptool()
    	# declaring IFS local in this function, removes the need to
    	# save/restore it
    	local IFS o
    	test -x $SDPTOOL || return 1
    # FIXME: where does SDPTOOL_OPTIONS come from?
    	if ! test -z "$SDPTOOL_OPTIONS" ; then
    		IFS=";"
    		for o in $SDPTOOL_OPTIONS ; do
    			#echo "execing $SDPTOOL $o"
    			IFS=" "
    			if [ "$VERBOSE" != no ]; then
    				$SDPTOOL $o
    			else
    				$SDPTOOL $o >/dev/null 2>&1
    			fi
    		done
    	fi
    hci_input()
        log_progress_msg "switching to HID/HCI no longer done in init script, see /usr/share/doc/bluez/NEWS.Debian.gz" || :
    alias enable_hci_input=hci_input
    alias disable_hci_input=hci_input
    start_uarts()
    	[ -f $HCIATTACH ] && [ -f $UART_CONF ] || return
    	grep -v '^#' $UART_CONF | while read i; do
                           $HCIATTACH $i
                   else
                           $HCIATTACH $i >/dev/null 2>&1
                   fi
    	done
    stop_uarts()
    	killall ${HCIATTACH##*/} >/dev/null 2>&1 || :
    start_rfcomm()
    	if [ -x $RFCOMM ] && [ -f $RFCOMM_CONF ] ; then
    		# rfcomm must always succeed for now: users
    		# may not yet have an rfcomm-enabled kernel
    		       log_progress_msg "${RFCOMM##*/}"
    		       $RFCOMM -f $RFCOMM_CONF bind all || :
                    else
    		       $RFCOMM -f $RFCOMM_CONF bind all >/dev/null 2>&1 || :
                    fi
    	fi
    stop_rfcomm()
    	if [ -x $RFCOMM ] ; then
    		       $RFCOMM unbind all || :
                   else
    		       $RFCOMM unbind all >/dev/null 2>&1 || :
                   fi
    	fi
    restart_rfcomm()
                   else
    		       $RFCOMM unbind all >/dev/null 2>&1|| :
                   fi
    	fi
    case $1 in
      start)
    	log_daemon_msg "Starting $DESC"
    	if test "$BLUETOOTH_ENABLED" = 0; then
    		log_progress_msg "disabled. see /etc/default/bluetooth"
    		log_end_msg 0
    		exit 0
    	fi
    #	start-stop-daemon --start $SSD_OPTIONS
    	start-stop-daemon --start $SSD_OPTIONS -- -d
    	log_progress_msg "${DAEMON##*/}"
    	run_sdptool || :
    	start_uarts || :
    	if test "$HID2HCI_ENABLED" = 1; then
    		enable_hci_input
    	fi
    	start_rfcomm || :
    	if test "$HIDD_ENABLED" = 1 ||
    		test "$PAND_ENABLED" = 1 || test "$DUND_ENABLED" = 1; then
    		log_progress_msg "compatibily daemons not started, see bluez-compat package"
    	fi
    	log_end_msg 0
      stop)
    	log_daemon_msg "Stopping $DESC"
    		log_progress_msg "disabled."
    		log_end_msg 0
    		exit 0
    	fi
    	stop_rfcomm || :
    	if test "$HID2HCI_UNDO" = 1; then
    		disable_hci_input
    	fi
    	start-stop-daemon --stop $SSD_OPTIONS
    	log_progress_msg "${DAEMON}"
    	stop_uarts || :
    	log_end_msg 0
      restart|force-reload)
    	$0 stop
    	sleep 1
    	$0 start
      status)
    	status_of_proc "$DAEMON" "$DESC" && exit 0 || exit $?
    	N=/etc/init.d/bluetooth
    	echo "Usage: $N {start|stop|restart|force-reload|status}" >&2
    	exit 1
    esac
    exit 0
    # vim:noet
    Then make it executable:
        • sudo chmod +x /etc/init.d/bluetooth
    and configure it for automatically start at boot:
        • sudo update.rc.d bluetooth defaults
    Reboot and your DT interface will be shown with command:
        • sudo hcitool dev
    N.B I'm quite sure this procedure will solve the problem, so I'm going to change subject in [solved]
  3. HixVAC
    HixVAC New Member
    Oct 25, 2013
    13
    Ahhh, you are awesome! Thank you, sir!
  4. g.cubed
    g.cubed New Member
    Oct 29, 2013
    Just wanted to make some minor corrections:
    sudo update-rc.d bluetooth defaults
  5. saidol
    saidol New Member
    Oct 3, 2013
    24
    Thanks g.cubed
  6. g.cubed
    g.cubed New Member
    Oct 29, 2013
    Thank you saidol!
  7. doraess
    doraess New Member
    Nov 1, 2013
    I've followed all those steps and noticed that in the latest ubuntu image bluez is correctly installed.
    However, executing
    sudo hcitool dev
    gives me nothing. It seems bluetooth dongle is not enabled or broken.
  8. Juwalla
    Juwalla New Member
    Oct 29, 2013
    I am a noob to Linux and Ubuntu so I am getting a little frustrated with the permissions for doing things. When I try to save the new file "step 2 above" I am being told that I don't have permission to save it. I cannot find any way to elevate my privilege. Can some one please break it down Barney style for the moron please?
  9. juncaofish
    juncaofish New Member
    Aug 8, 2013
    After following this instruction, just get nothing for sudo hcitool dev . I can't make bluetooth work for my quad udoo. All settings got disabled in bluetooth configure page for system setting. Any idea?
  10. Stéphane Mouton
    Stéphane Mouton UDOOer
    Jul 30, 2016
    I've got exactly the same problem. Though bluez is installed and started according to the init script above, hcitool returns nothing.
  11. Stéphane Mouton
    Jul 30, 2016
    The following command solved the problem
    sudo hciconfig hci0 reset​
    Hope it may help somebody
    Andrea Rovai and waltervl like this.
