Hello, I'm trying to compile udoobuntu minimal for Neo Full but I'm having troubles. At a point of the compile process the following message appears and the compilation is aborted: Code: Extracting templates from packages: 100% Preconfiguring packages ... Fetched 35.5 MB in 12s (2937 kB/s) (Reading database ... 11938 files and directories currently installed.) Preparing to unpack .../base-files_7.2ubuntu5.4_armhf.deb ... Progress: [ 0%]Unpacking base-files (7.2ubuntu5.4) over (7.2ubuntu5) ... terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc qemu: uncaught target signal 6 (Aborted) - core dumped include/debootstrap.sh: line 118: 4923 Aborted (core dumped) chroot "$ROOTFS/" /bin/bash -c 'PATH=/fake:$PATH apt -y full-upgrade' Any idea of what is happening? I attach a file with the full compilation process. Thanks in advance, Regards, Antonio.
Hi there, Maybe you were out of memory... Can you give more information on the machine you're using? Also share dmesg if you can.
Hello Ektor, Thanks for replying! I'm using a develompent enviroment as the described in the Neo documentation (virtual machine with ubuntu 14.04). I think that it is not a memory problem, because I had 2GB assigned to the vm and I have rised the memory amount to 3GB but the compilation stops at the same point. I have attached dmesg in in file in this post. Regards, Antonio.
Other info? VM Architecture, VM version... Also, have you updated your Ubuntu 14.04? mkudoobuntu uses a chroot with a qemu-static emulation... It could be that an old qemu have issues with the newest VMs... Code: sudo apt update && sudo apt upgrade Ek5
Hello Ektor, Definitetly the problem should be something wring in the distribution (probably something I installed or updated before) beause a college has test it in a clean virtual machine and it has succed. Thanks for your help! Regards, Antonio.
