Switch video output from HDMI to LVDS
Discussion in 'Linux Ubuntu' started by Rafael Asrael, Dec 12, 2016.
  1. Rafael Asrael
    Rafael Asrael New Member
    Dec 8, 2016
    I HAVE THIS PROBLEM WITH UBUNTU, WHEN I TURN ON THE UDOO BOARD, ONLY APPEARS THE SCREEN WHICH I ATTACHED IN THIS TEXT (THE IMAGE), AND FINALLY THE SCREEN BECOME BLACK AND THE HDMI SAYS THAT THERE IS NO SIGNAL, SOMEBODY CAN TELL WHAT HAPPEN
  2. Andrea Rovai
    Hi Rafael,
    first: avoid using only capital letters.
    Second: have you followed the guide for what concerns LVDS?
  3. waltervl
    I believe you have an Udoo Quad. Can try to rewrite a fresh downloaded Udoobunto 2 image on your SD card. Even better on another (new?) SD card. Bad downloaded or bad written images are the most common issues in not starting Udoobuntu.
    And do you have also a separate Udoo LVDS (touch) screen? Did you follow the instructions http://www.udoo.org/docs/Hardware_&_Accessories/UDOO_LVDS_Panels.html
  4. Rafael Asrael
    Dec 8, 2016
    Yes I follow the instructions but when I type sudo udooscreenctl set lvds15
    Appears me a message that the command doesn't exit
  5. waltervl
    What Udoobuntu version did you download?
  6. Rafael Asrael
    Dec 8, 2016
  7. waltervl
  8. Rafael Asrael
    Dec 8, 2016
    Sorry i tried with another sd card and the Vnc but nothing works do you think that I could be my udoo board?in the case that my udoo board doesn't work can I ge tenical support ?
  9. waltervl
    I think you have another problem.
    The command should be available in Udoobuntu 2. If you have an hardware problem it won't boot at all.
    Can you connect your Udoo to your network with a network cable? Boot the Udoo without a monitor attached. Can you open the web control panel of the Udoo from another PC (http://IP-of-your-Udoo)?
  10. waltervl
    Any luck so far?
