UDOObuntu 2.1 (Ubuntu 14.04) won't boot from SATA [SOLVED]
Discussion in 'UDOO QUAD' started by damoreluc, Oct 18, 2016.
  1. damoreluc
    damoreluc New Member
    Dec 9, 2013
    15
    Hi all,
    I followed the instructions from here but the boot process hangs just before its ending.
    This is what I get in U-Boot with the sata info command:
    => sata info
    SATA device 0: Model: KINGSTON SV300S37A60G Firm: 608ABBF0 Ser#: 50026B72630E9F8
                Type: Hard Disk
                Supports 48-bit addressing
                Capacity: 57241.8 MB = 55.9 GB (117231408 x 512)
    so the SATA device is visible.
    That's the output of the boot process:
    U-Boot SPL 2015.10-00062-g8af36f3 (Mar 08 2016 - 16:53:02)
    U-Boot 2015.10-00062-g8af36f3 (Mar 08 2016 - 16:53:02 +0100)
    CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
    Reset cause: POR
    Board: UDOO Quad
    DRAM:  1 GiB
    MMC:   FSL_SDHC: 0
    *** Warning - bad CRC, using default environment
    No panel detected: default to HDMI
    Display: HDMI (1024x768)
    In:    serial
    Out:   serial
    Err:   serial
    Net:   using phy at 6
    FEC [PRIME]
    switch to partitions #0, OK
    mmc0 is current device
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: ncq stag pm led clo only pmp pio slum part
    SATA Device Info:
    S/N: 50026B72630E9F48
    Product model number: KINGSTON SV300S37A60G
    Firmware version: 608ABBF0
    Capacity: 117231408 sectors
    reading uEnv.txt
    52 bytes read in 121 ms (0 Bytes/s)
    Running bootscript from mmc ...
    Device Tree: dts/imx6q-udoo-hdmi.dtb
    reading zImage
    4547280 bytes read in 47 ms (92.3 MiB/s)
    Booting from mmc ...
    reading dts/imx6q-udoo-hdmi.dtb
    41714 bytes read in 8 ms (5 MiB/s)
    Kernel image @ 0x12000000 [ 0x000000 - 0x4562d0 ]
    ## Flattened Device Tree blob at 18000000
       Booting using the fdt blob at 0x18000000
       Using Device Tree in place at 18000000, end 1800d2f1
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 3.14.56-udooqdl-02021-g724c68a (udooer@udoo_compil6
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
    [    0.000000] Machine model: UDOO Quad Board
    [    0.000000] cma: CMA: reserved 320 MiB at 3c000000
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] PERCPU: Embedded 8 pages/cpu @ab723000 s8256 r8192 d16320 u32768
    [    0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/sda2 rootw1
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
    [    0.000000]     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    [    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    [    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
    [    0.000000]       .text : 0x80008000 - 0x80abda64   (10967 kB)
    [    0.000000]       .init : 0x80abe000 - 0x80afc040   ( 249 kB)
    [    0.000000]       .data : 0x80afe000 - 0x80b3a9c0   ( 243 kB)
    [    0.000000]        .bss : 0x80b3a9cc - 0x80b9cb5c   ( 393 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000759] Console: colour dummy device 80x30
    [    0.000779] Calibrating delay loop (skipped), value calculated using timer f)
    [    0.000794] pid_max: default: 32768 minimum: 301
    [    0.000973] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000987] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.008684] Initializing cgroup subsys devices
    [    0.008698] Initializing cgroup subsys freezer
    [    0.008727] CPU: Testing write buffer coherency: ok
    [    0.101291] Brought up 4 CPUs
    [    0.137086] CPU identified as i.MX6Q, silicon rev 1.2
    [    0.137180] Use WDOG1 as reset source
    [    1.164666] loop: module loaded
    [    1.169274] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, usin4
    [    1.177227] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, usi0
    [    1.185258] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, u0
    [    1.193447] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 00
    [    1.203921] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
    [    1.210920] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0xe
    [    1.219741] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp
    [    1.230289] scsi0 : ahci_platform
    [    1.233954] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x1
    [    1.455260] mmc0: no vqmmc regulator found
    [    1.459371] mmc0: no vmmc regulator found
    [    1.503805] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADA
    [    1.552205] mmc0: host does not support reading read-only switch. assuming w.
    [    1.567375] mmc0: new high speed SDHC card at address 0002
    [    1.573823] mmcblk0: mmc0:0002 SD16G 14.9 GiB
    [    1.580532]  mmcblk0: unknown partition table
    [    1.783841] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    [    1.797204] ata1.00: ATA-8: KINGSTON SV300S37A60G, 608ABBF0, max UDMA/133
    [    1.804040] ata1.00: 117231408 sectors, multi 1: LBA48 NCQ (depth 31/32)
    [    1.815940] ata1.00: configured for UDMA/133
    [    1.820950] scsi 0:0:0:0: Direct-Access     ATA      KINGSTON SV300S3 BBF0 P5
    [    1.830003] sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55)
    [    1.838078] sd 0:0:0:0: [sda] Write Protect is off
    [    1.843021] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doeA
    [    1.853811]  sda: sda1 sda2
    [    1.858309] sd 0:0:0:0: [sda] Attached SCSI disk
    [    2.094096] EXT4-fs (sda2): recovery complete
    [    2.098622] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts:)
    [    2.106338] VFS: Mounted root (ext4 filesystem) on device 8:2.
    [    2.112463] devtmpfs: mounted
    [    2.115615] Freeing unused kernel memory: 248K (80abe000 - 80afc000)
    [    2.301529] random: init urandom read with 27 bits of entropy available
    [    2.454807] init: mounted-proc main process (118) terminated with status 1
    [    3.224323] ov5640_read_reg:write reg error:reg=300a
    [    3.346308] ERROR: v4l2 capture: slave not found!
    [    3.355458] ERROR: v4l2 capture: slave not found!
    and it stops there.
    I wonder if the boot image for UDOObuntu 2.0 (the one you can download from the page Boot from SATA) is good also for UDOObuntu 2.1. If not, where we can get it?
    Last words: UDOObuntu2.1 runs flawlessly with the bootable microSD card alone.
    Thanks in advance for your help.
    Andrea Rovai likes this.
  2. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
    Please could you try to boot without the HDMI cable connected?
  3. damoreluc
    Dec 9, 2013
    15
    Hi Francesco,
    yes I'm trying to boot *without* HDMI cable connected. That's what I get.
    Btw, the boot process stop at the same step also with the HDMI cable connected.
  4. damoreluc
    Dec 9, 2013
    15
    Udoo finally boots from SATA after changing SD card (a few of...)
    I've noticed that it takes some seconds to prompt the console:
    [    3.468442] ERROR: v4l2 capture: slave not found!
    [ OK ]ting up X socket directories...
    [ OK ]ding cpufreq kernel modules...
    [ OK ]Freq Utilities: Setting ondemand CPUFreq governor...         * CPU0...
    [ OK ]ting sysfs variables...
    * Starting NTP server ntpd        [   13.194472] imx-hdmi-audio imx-hdmi-audio!
    [   13.202974] imx-hdmi-audio imx-hdmi-audio: ASoC: can't open platform imx-hdm2
    [   13.213690] imx-hdmi-audio imx-hdmi-audio: HDMI Video is not ready!
    [   13.228579] imx-hdmi-audio imx-hdmi-audio: ASoC: can't open platform imx-hdm2
    [ OK ]
    UDOObuntu v2.1
    default username:password is [udooer:udooer]
    udoo login: udooer
    Password:
    Last login: Fri Jan  1 00:00:23 UTC 2016 on ttymxc1
    Welcome to Ubuntu 14.04.5 LTS (GNU/Linux 3.14.56-udooqdl-02021-g724c68a armv7l)
    * Documentation:  http://www.udoo.org/docs/
    udooer@udoo:~$
    I don't know if this is ok or not.
  5. Francesco
    Jun 23, 2015
    220
    110
    Hi damoreluc, so you have just changed SD card in order to boot properly?
    A few seconds are necessary for the login console to appear. If you want to know what is blocking, you need some metering tool like bootchartd. Or if you try the Ubuntu 16.04 image you can use the builtin `systemd-analyze` tool to find the bad guy.
  6. damoreluc
    Dec 9, 2013
    15
    Yes, now I'm using a Class 4 SD card. It works fine.
    ok, I'll give a try to bootchartd.
    BTW, is Ubuntu 16.04 image still a release candidate?
  7. Francesco
    Jun 23, 2015
    220
    110
    Ubuntu 16.04 is alpha. If you want something stable I recommend you 14.04 and try bootchartd.
  8. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    The directions at http://www.udoo.org/docs/Hardware_&_Accessories/Boot_from_SATA.html, I think, are not correct for version 2.1. Could somebody try and give a more general description of what should be typed into /dev/sd??/etc/fstab? I still can't get my quad to boot from SATA.
  9. damoreluc
    Dec 9, 2013
    15
    Hi sirrab,
    this is my /etc/fstab, it works on my UDOO Quad:
    /dev/sda2  /      ext4   defaults,noatime              0  0
    /dev/sda1  /boot  vfat   defaults,noatime              0  0
    Remember to edit your /etc/fstab file while your SATA disk is still connected to the machine you used to flash the UDOOBuntu 2.1 image. Delete any previous content in the /etc/fstab.
    Of course, be carefull to edit the /etc/fstab file on the disk you'll used on the UDOO, not the one on your computer.
    Have you flashed also the bootloader on the SD card?
    Let me know if this helps you.
  10. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Removing what was there might help. My SSD has 2 partitions, 1st is 34MB and not mountable, 2nd partition is udoobuntu and is ~2.8GB. 2nd partition has a Linux file system and typical folders.
  11. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Had a bad microSD card. Starts to boot, stops at ERROR: v4l2 capture: slave not found!
    What does this mean?
