vivante 5.0.11.p4.5 problems
Discussion in 'Kernels' started by vpeter, Feb 1, 2016.
  1. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
    I'm seeking some help with unofficial kernel I'm trying to use (3.14.54 from solidrun and 4.4 from xbian) with openelec. Few months back I had everything running but now I have video on hdmi and 7" LVDS 800x480 but 15" LVDS 1366x768 doesn't work. Kodi is saying the text below. Splash is visible in all 3 cases.
    I would be very glad if someone could help me with this.
    Thanks in advance for any tip to get this running.
    18:20:42 T:3034268208  NOTICE: Initialize - graphics sysfs is writable
    18:20:42 T:3034268208  NOTICE: Initialize - 32bpp: configure alpha blending
    18:20:42 T:3034268208  NOTICE: InitWindowSystem: Using EGL Implementation: iMX
    18:20:42 T:3034268208  NOTICE: Found resolution 1366 x 768 for display 0 with 1366 x 768 @ 55.000000 Hz
    18:20:42 T:3034268208  NOTICE: Found (1366x768@55.000000) at 16, setting to RES_DESKTOP at 16
    18:20:42 T:3034268208  NOTICE: Checking resolution 16
    18:20:42 T:3034268208   ERROR: EGL error in CreateSurface: 3003
    18:20:42 T:3034268208  NOTICE: CreateWindow: Could not create a surface. Trying with a fresh Native Window.
    18:20:42 T:3034268208   ERROR: CreateWindow: Could not create surface
    18:20:42 T:3034268208   ERROR: CreateNewWindow: Could not create new window
    18:20:42 T:3034268208   FATAL: CApplication::Create: Unable to create window
    I noticed that if I change resolution to 1368x768 kodi starts. Wondering why...
    00:10:36 T:3034133040  NOTICE: Initialize - graphics sysfs is writable
    00:10:36 T:3034133040  NOTICE: Initialize - 32bpp: configure alpha blending
    00:10:36 T:3034133040  NOTICE: InitWindowSystem: Using EGL Implementation: iMX
    00:10:36 T:3034133040  NOTICE: Found resolution 1368 x 768 for display 0 with 1368 x 768 @ 57.000000 Hz
    00:10:36 T:3034133040  NOTICE: Found (1368x768@57.000000) at 16, setting to RES_DESKTOP at 16
    00:10:36 T:3034133040  NOTICE: Checking resolution 16
    00:10:36 T:3034133040  NOTICE: GL_VENDOR = Vivante Corporation
    00:10:36 T:3034133040  NOTICE: GL_RENDERER = Vivante GC2000
    00:10:36 T:3034133040  NOTICE: GL_VERSION = OpenGL ES 3.0 V5.0.11.p4.25762
    00:10:36 T:3034133040  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
    00:10:36 T:3034133040  NOTICE: GL_EXTENSIONS = GL_OES_vertex_type_10_10_10_2 ..........
    Andrea Rovai likes this.
  2. Andrea Rovai
    Hi vpeter,
    I've shared your help request on UDOO's Facebook page.
  3. vpeter
    Nov 29, 2014
    303
    62
    I think I fixed already. The problem is that IPU needs X and Y by modulo 8 and driver in my kernel doesn't fix that. 1366 is not by module 8. Only 1360 or 1368.
    Seems I'm on track to use new kernel for my imx6 devices. One nice feature with 4.4 kernel is docker support.
  4. patrykk
    patrykk Member
    Dec 10, 2014
    52
    Hi, Do you know where is a problem, I have that same on 5.0.11p7.3
  5. vpeter
    Nov 29, 2014
    303
    62
    Not sure if correct solution but I changed in dts resolution from 1366x768 to 1360x768. So both are divided by modulo 8. And IPU seems to be happy ;)
    Now there is small black vertical bar few pixels width at the right part of the screen.
