What temeperatures are normal?
Discussion in 'UDOO X86' started by Morish, Apr 20, 2017 at 7:15 PM.
  1. Morish
    Morish New Member
    Thursday
    I just got my x86 in the mail yesterday and I was a bit surprised to see how hot it gets (it idles at around 70 c).
    so my main question is if this normal?
    Do I need get a fan for the heatsink?
  2. mkopack
    mkopack Member
    407
    What OS are you running on it? It's possible that the power profile is set to high performance and never letting it clock down or turn off cores not in use.... Check and make sure it's set to balanced or something like that. Or, yeah, get a fan if you aren't comfortable with the temps... Never hurts.
  3. x1800MODMY360x
    x1800MODMY360x New Member
    Mar 29, 2017
    12
    It's a passive cooling so depending on the work load, that can be a factor on the temp. The temperature of the room can also be a factor as well.
  4. Markus Laire
    Markus Laire Member
    Mar 9, 2017
    31
    According to manual, heatsink temperature must never go above 60 C.
    Quote from manual: "Temperatures indicated are the maximum temperature that the
    heatspreader / heatsink can reach in any of its parts. This means that it is
    customer ’ s responsibility to use any passive cooling solution along with an
    application-dependent cooling system, capable to ensure that the
    heatspreader / heatsink temperature remains in the range above indicated."
  5. Kilrah
    Kilrah New Member
    Thursday
    16
    I've recorded 87°C core temp today, as delivered and in free air.
    A fan should really have been delivered standard, the board as it is can not be used at its published specs.
    That's just BS, why supply a heatsink at all then if it's not suitable anyway.
    Markus Laire likes this.
  6. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    282
    91
    I agree, the on board heat sink seems to be wholly inadequate for 6W TDP. Intel are quoting 6W at Base Frequency (not Burst):
    "Thermal Design Power (TDP) represents the average power, in watts, the processor dissipates when operating at Base Frequency with all cores active under an Intel-defined, high-complexity workload."
  7. Andrea Rovai
    Andrea Rovai Administrator Staff Member
    1,676
    219
    To the best of my knowledge, the manual refers to the heatsink when it specifies the temperature limit, not to the core processor.
    You measured the temperature of the processor, did you?
    I wanted to reasurre you anyway that we have made tests in a climatic chamber.
  8. Markus Laire
    Markus Laire Member
    Mar 9, 2017
    31
    Manual refers to any part of heatsink, including parts which touch processor - so this means that surface temperature of processor must not ever reach 60 C, according to manual.
  9. Laura
    Laura Active Member
    Apr 22, 2016
    182
    80
  10. Kilrah
    Kilrah New Member
    Thursday
    16
    Yup, but it looks like at full CPU load the temp difference between CPU and heatsink is < 10°C.
    The CPU starts throttling once a core hits 86°C (when there is no GPU use).
