Where is Neo 'Configuration' ? It has been replaced by 'Quick Configuration', which doesn't set passwords, timezones, etc. How can I invoke the old 'Configuration' webpage ? B.A.C.
??? You mean the web control panel? It is still where it always was http://www.udoo.org/docs-neo/Basic_Setup/Web_Control_Panel.html Or are you using Android 6? There settings are moved to the settings menu. http://www.udoo.org/docs-neo/Cookbook_Android/UDOO_Android_Settings.html
(1) That's just the docs, I mean the real thing. What I have is shown in: http://www.udoo.org/an-updated-enhanced-web-control-panel-for-udoo-neo/ Note that the 'Configuration' menu item is replaced by 'Quick Configuration', which is useful but does not do what the 'Configuration' did. So how can I invoke the 'Configuration' ? (2) No, I'm using Ubuntu.
It should do the same. Perhaps you do not see the submenu under configuration? Use another browser (firefox) to check?
Ah wait if you have a "Quick configuration" menu you an old version of Udoobuntu and you should update. This news update is already one year old http://www.udoo.org/an-updated-enhanced-web-control-panel-for-udoo-neo/
If that is the case then it's a puzzle -- I purchased the official SD card in Oct-2016, and I updated the OS yesterday. So the question remains, how do I invoke the 'Configuration' ?
I have Udoobuntu 2.1 running and I have a configuration menu as displayed in the documentation. This should do the trick. sudo apt-get update sudo apt-get dist-upgrade reboot your Neo
How do you find out what version of Udoobuntu is running? [ /etc/issue says: Ubuntu 14.04 LTS \n \l ]
I don't know how to see what version you have. Perhaps you better download the latest Udoobuntu 2 image from the download page and write it to the SD card. http://www.udoo.org/docs-neo/Getting_Started/Create_a_bootable_MicroSD_card_for_UDOO_Neo.html
Great! That worked, many thanks. Nice yoke, very neat. I'm using it to collect ambient temperature using the LM175b. I want to collect both inside & outside temps but the LM175b daisy-chain cables are too short to get through the wall to outside -- it would help if they were twice as long. Any idea where I'd get a cable with male & female connectors that could be used to extend the daisy chain? Also a really good idea would be to fix things so DHCP*actually* works for the WiFi link. B.A.C
You mean the TMP75b? I believe these cannot be daisy chained because they all have the same I2C address. You could use the MPL3115 kit to daisy chain it with which also can measure temperature. Concerning the cable you can cut the old cable in the middle and solder an extension in between. It is advised to use a shielded cable as the I2C protocol was not designed for meters of in between distance.
If you already have the 2 temp sensors you could attach one of them on the I2C_4 bus on other pins of the Neo: http://www.udoo.org/docs-neo/Hardware_&_Accessories/I2C_bus.html . In this case they use different busses.
Yes, the two sensors I have are the TMP75b. Their website says "UDOO Bricks work along a cascade configuration", but I'll test them tomorrow. I'll take you advice and splice in a 30cm extension. B.A.C
Sorry, yes, I had it working as soon as the OS was updated, but only for one sensor. I'm somewhat diverted by Christmas, so will not get around to extending the sensor cable until the New Year. Thankyou very much, I'll let you know when the cable extension is done, B.A.C
