Yocto + Qt5 + LVDS on i.MX6 (FSL Community BSP): Rendering and color depth
Discussion in 'Yocto' started by juliend, Jan 18, 2017.
  1. juliend
    juliend New Member
    Oct 14, 2016
    I've made my own yocto image for a Udoo neo board using graugans/meta-udoo, in eglfs mode (no X11 / Wayland), following this tutorial : http://wiki.wandboard.org/index.php/Building_Qt5_using_yocto_on_Wandboard
    Then I developped a simple QT5 application displayed on Udoo's 7" LVDS display.
    The rendering of my image is not correct. It seems to be displayed in R/G/B/A = 4/4/4/0 instead of 6/6/6/0.
    How can I specify this values before launchning my application ?
    Moreover, transparency is not correctely managed on LVDS (but works fine on my PC), could it be a matter with ALPHA value ?
    I launch my application by running this script :
    Application logs :
    Many thanks,
  2. modjo
    modjo Active Member
    Sep 29, 2014
    383
    116
    Hi i never had this problem, perhaps an issue with dts for lvds 7 ! If you use the official distribution udoobuntu (or the yocto image build with Graugans), did you have the same problem ?
  3. juliend
    juliend New Member
    Oct 14, 2016
  4. modjo
    modjo Active Member
    Sep 29, 2014
    383
    116
    Ok could you try with my build for neo here and let me know (it work fine for me with lvds7 ...)
    Otherwise, there are a beta version of udoobuntu (16.04 ) that have Qt5 natively here ...
