if i use Serial.println then stop process
Discussion in 'Arduino IDE' started by simcode, Dec 3, 2013.
  1. simcode
    simcode New Member
    Dec 2, 2013
    why?
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Correction to my earlier post.
    It's clear that if you pass an unsupported data type to Serial then it will hang the SAM3X8E. EG pass it a Float and it hangs. However the 'Serial' library is documented as supporting "any data type" (not sure they mean that literally, but for sure Strings and Floats are supposed to work out of the box). Clearly it doesn't.
    Here is a workaround (for strings), use an array of chars with a Null terminator.
    char myTestString [ ] = "Test raw char *\0";
    Serial.println(myTestString);
  3. simcode
    simcode New Member
    Dec 2, 2013
    thank you.
    but i don't run.
    if i use Serial library then stop process
  4. jdonavan
    jdonavan New Member
    Oct 28, 2013
    34
    If you pass an unsupported data type to the Serial class it will result in a COMPILE error not a runtime error.
  5. Lifeboat_Jim
    Sep 16, 2013
    399
    Well, all data types are supposed to be supported by Serial but there is clearly an issue at Compile stage that only exhibits at runtime.
    A ticket has been created and Team UDOO are looking into this currently.
  6. andcmp
    andcmp New Member
    161
    This is something related to the Arduino IDE compiler. We are working on it and we should solve the problem with an update in the near future.
  7. taylo1g
    taylo1g New Member
    Oct 30, 2013
