External Programming Issue
Discussion in 'UDOO DUAL' started by Joe_Lowtech, Oct 13, 2017.
  1. Joe_Lowtech
    Joe_Lowtech New Member
    Oct 13, 2017
    Hello,
    I need some help with the external programming. The Udoo Board is working when i use the onboard Arduino IDE.
    But for some reason, the uploading of the sketch does not work correctly when im trying to load the Sketch from my pc.
    I can upload it once after shutting down the udoo but this is the only time it works. All the other times i get this error message:
    Output:
    No device found on COM10
    Sending auth and 0xF command
    /arduinoPlugin/packages/UDOO/tools/bossac-udoo/1.3a-1.0/bossac-udoo.exe finished
    upload done
    Im using the Sloeber IDE but i get the same error message with Arduino IDE.
    Any help on that matter is appreciated
    Regards
    Joe_Lowtech
