Hi I have a PC with Windows 7 without administrator password. So I'm using an Oracle VirtualBox VM with newest Ubuntu. I am able to activate USB forwarding for the Udoo, and the Ubuntu is creating a new interface for the udoo. But it doesn't get an IP address (192.168.7.1). I'm further able to connect to the udoo by using minicom... How can I reset the IP configuration? dhclient doesn't work. How is the IP configuration handled? Thank you for any hints!
@szhvoj, I found that setting a wider range of IP in interfaces and dhcp makes everything faster and more reliable. So /etc/network/interfaces: Code: [...] # USB OTG connection allow-hotplug usb0 iface usb0 inet static address 192.168.7.2 netmask 255.255.255.0 [...] and /etc/dhcp/dhcpd.conf Code: [...] subnet 192.168.7.0 netmask 255.255.255.0 { option routers 192.168.7.2; option subnet-mask 255.255.255.0; range 192.168.7.1 192.168.7.100; } [...]
