15.6 Touch Screen Mount
Discussion in 'Accessories' started by dantavious, Mar 3, 2014.
  1. dantavious
    dantavious New Member
    Nov 29, 2013
    32
    I was under the impression that Touch Screen would come with attachments that would allow it to stand on its on. Since it did not,
    where can I buy such hardware. Thanks
    Derrick
  2. ericwjr
    ericwjr New Member
    Feb 26, 2014
    This is good point. I've noticed that when I lay screen on table flat, touch works...when I stand it up with my hand, touch doesn't work. I'm thinking this is a HW issue. Any thoughts?
  3. dantavious
    Nov 29, 2013
    32
    I will hook mine up in the next couple days and see if I have the same issue. If so, that is a problem.
  4. ericwjr
    ericwjr New Member
    Feb 26, 2014
    Disregard my problem, I have no issue. You can't hold it up with your hand because it's capacitive haha.
  5. dantavious
    Nov 29, 2013
    32
    So what are you using to hold it up? What stand and where can I buy one?
  6. ericwjr
    ericwjr New Member
    Feb 26, 2014
    I wasn't using a stand...I just leaned it up against a non-capacitive surface.
    On another note:
    I've noticed that with 15.6" touch screen the touch doesn't respond for some people when I have them touch the screen. They end up having to apply more pressure (to get larger surface area). If someone with very dry hands touches the screen it doesn't respond either. It clearly seen with drags.
    Is there anyway I can boost capacitance? Any ideas?
  7. dantavious
    Nov 29, 2013
    32
    SOLVED 15.6 Touch Screen Mount
    I took a chance on ordering 2 of the 8-10 wire stands from Adafruit and the work great for my purposes. What sucks is I ordered the 15.6 Touch and received the non Touch Screen, which sucks. :(
