2.4GHz Wireless Mouse Not Working in the login screen of Win10
Discussion in 'UDOO BOLT' started by hhtmp88, Aug 16, 2019.
  1. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    52
    Dear all,
    Anyone experienced the following problems:
    * 2.4GHz Wireless Mouse Not Working in the login screen of Win10
    -- and need to unplug and then re-plug the 2.4GHz USB transceiver to make the mouse working again after login
    * My Hardware/OS Configuration:
    # Udoo Bolt V8
    # 8GB DDR4-2400 SO-DIMM (Corsair Vengeance CMSX8GX4M1A2400C16)
    # 250GB 2.5" SSD (Crucial MX500)
    # USB Type-C PD3.0 Power Adaptor
    # 2.4GHz Wireless Mouse connected to one of the USB3.0 port of Bolt
    # USB Keyboard connected thru the Bonus USB Type-C Hub
    # UEFI BIOS Default Recovery Switch Position: Left
    # OS: Win10 Pro v.1809 64bit (built 17763.678)
    -- Cloned directly from the 2.5" SSD of another Desktop miniPC (AsRock J5005-ITX Mainboard)
    How to solve the problems?
    Thanks!
    Cloned the OS??
    Why not a proper install, this will result in the correct drivers.
  3. ccs_hello
    536
    194
    re: need unplug then replug
    Please note there are so many "proprietary" cordless mouse designs that use various method to "bind" the mouse with the accompanying mouse-transceiver-dongle.
    In my experience, especially the $$ ones, they typically pre-shipped with dongle-mouse pre-bundled/bound, no additional work needed. If need to rearrange, a separate re-configuration software or a hidden button is used to re-config.
    The $ ones are everyone's guess. Often times, the mouse will bind to the first dongle when it "sees". It means a complete power down then turn on the UDOO Bolt power will trigger a re-binding process. < --- this is most likely the case that you need to unplug the dongle (means power-down and release the binding; then start-over the re-negotiation)
    How bad is it? Tell a funny story. I used to have a small setup with multiple PCs with the several mice (same mouse make/model.)
    It became a nightmare all depends on the actual sequence how individual PC got powered up, the mouse family is assigned to individual PC "by chance". I have to move the mouse to see which is which "this time this mouse is assigned to that PC". What a fun time!
    $ priced mouse -- > you get what you paid for
  4. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    52
    It is just plug and play,
    I don't need any specific driver for exactly the same wireless mouse to work properly on both :
    (a) AsRock J5005-ITX Mainboard with Win10 v.1809 64bit installed on a 2.5"SSD
    -- I exactly clone the Win10 of this SSD for Udoo Bolt.
    (b) A J1900-ITX Mainboard with Win10 v.1809 32bit
  5. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    52
    I am not sure if you really described similar scenario as me!
    (b) and A J1900-ITX Mainboard with Win10 v.1809 32bit
    No replug is required on (b)!
  6. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    52
    Anyone that can use wireless Mouse without any problems?
  7. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    I use a Logitech wireless keyboard with a touch pad on Ubuntu without any problems. It also works on my Windows machines. The USB dongle just looks like a wired mouse and a wired keyboard to the OS I think.
