Android Build Failed for UDOO Neo (udooneo_6sx-eng)
Discussion in 'UDOO NEO' started by kkaran_2010, Nov 25, 2019.
  1. kkaran_2010
    kkaran_2010 UDOOer
    Nov 25, 2019
    Hi All,
    I am new to UDOO. I have a UDOO Full board with iMx6SoloX Processor. I am trying to build Android for the same board and following the below steps I found on UDOO official web site, but unfortunately the build cannot start as the file "device/udoo/imx6/udooneo_6sx.mk" is not present. I copied the file from GIT and tried but still cannot able to make as the file "out/build-udooneo_6sx.ninja" failed to generate.
    Can someone help me to build Android for my UDOO Neo Full board?
    Steps I follow to build are,
    1. Downloaded source from https://www.udoo.org/docs/Advanced_Topics/Compile_Android_From_Source.html
    2. mkdir myandroid
    3. mkdir bin
    4. cd myandroid
    5. curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ../bin/repo
    6. chmod a+x ../bin/repo
    7. ../bin/repo init -u https://github.com/UDOOboard/android_udoo_platform_manifest -b android-7.1
    ** Tried android-6.0.1 and android-7.1
    8. ../bin/repo sync
    9. lunch
    ** selected "udooneo_6x-eng" in lunch
    10. make -j8
    It mostly fails on 9th or 10th step. I tried to build for "udoo_6dq-eng" and it started the build but failed in make at 47% with out of memory, I will try to clean up my PC and try that again.
    FAILED: /bin/bash out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/with-local/classes.dex.rsp
    Out of memory error (version 1.2-rc4 'Carnac' (298900 f95d7bdecfceb327f9d201a1348397ed8a843843 by android-jack-team@google.com)).
    GC overhead limit exceeded.
    Try increasing heap size with java option '-Xmx<size>'.
    Warning: This may have produced partial or corrupted output.
    [ 47% 18304/38561] Building with Jack: out/target/common/obj/JAVA_LIBRARIES/android-opt-timezonepicker_intermediates/classes.jack
    ninja: build stopped: subcommand failed.
    build/core/ninja.mk:148: recipe for target 'ninja_wrapper' failed
    make: *** [ninja_wrapper] Error 1
    Please help me to build Android for UDOO Neo Full "udooneo_6x-eng" or "udooneo_6x-user"
    Thanks,
    Karan
  3. kkaran_2010
    kkaran_2010 UDOOer
    Nov 25, 2019
  4. kkaran_2010
    kkaran_2010 UDOOer
    Nov 25, 2019
  5. kkaran_2010
    kkaran_2010 UDOOer
    Nov 25, 2019
  6. kkaran_2010
    kkaran_2010 UDOOer
    Nov 25, 2019
    Hi All,
    Can you please help me to build Android-7.1 for UDOO neo full?
    I am getting below error after "repo sync"
    Procedure I followed:
    1) ../bin/repo init -u https://github.com/UDOOboard/android_udoo_platform_manifest -b android-7.1
    2) ../bin/repo sync
    3) export ARCH=arm
    4) source build/envsetup.sh
    5) lunch
    output:
    You're building on Linux
    Lunch menu... pick a combo:
    1. aosp_arm-eng
    2. aosp_arm64-eng
    3. aosp_mips-eng
    4. aosp_mips64-eng
    5. aosp_x86-eng
    6. aosp_x86_64-eng
    7. udoo_6dq-eng
    8. udoo_6dq-user
    9. udooneo_6sx-eng
    10. udooneo_6sx-user
    I have selected 9 and got below error.
    Which would you like? [aosp_arm-eng] 9
    build/core/product_config.mk:239: *** _nic.PRODUCTS.[[device/udoo/imx6/udooneo_6sx.mk]]: "device/udoo/imx6/udooneo_6sx.mk" does not exist. Stop.
    ** Don't have a product spec for: 'udooneo_6sx'
    ** Do you have the right repo manifest?
    Can anyone please help me with this?
    Thanks,
    Karan
  7. waltervl
    Looks like the same error as in Android 6. Did you try to implement the same fix as for Android 6?
  8. kkaran_2010
    kkaran_2010 UDOOer
    Nov 25, 2019
    Hi Waltervl,
    Yes I have tried the same Solution, but everything in "device/udoo/udooneo_6sx/BoardConfig.mk" file looks correct.
    Thanks,
    Karan
