Arduino freeze when declare String variable
Discussion in 'Arduino IDE' started by y.seksit, May 9, 2014.
  1. y.seksit
    y.seksit New Member
    May 8, 2014
    17
    Simple program with String variable will make Arduino freeze, source code like below
    void loop()
    String myStr = "";
  2. peter247
    peter247 New Member
    Mar 10, 2014
    263
    How do you know it`s freezing with your code , it`s not doing anything .
  3. y.seksit
    y.seksit New Member
    May 8, 2014
    17
    My code like below, Due freeze when i comment variable String recv = "", when I change it to Charactor array like char recv[200];, code will work fine,
    String recv = "";
    void setup(){
    Serial.begin(9600);
    void loop(){
    while (Serial.available())
    char ch = Serial.read();
    recv += ch;
    if (ch = '\n') {
    Serial.println(recv);
  4. Simsy
    Simsy New Member
    Jan 12, 2015
    Hi, I've got a similar issue with the Due freezing when certain code is included. Did you manage to get to the bottom of what was going on with your issue ?
