Hi, After installing debian and then java6 jdk and jre, I installed the Arduino IDE, only to get the following errors, please assist: root@udoo:~# ./arduino-1.5.4/arduino java.lang.UnsatisfiedLinkError: /root/arduino-1.5.4/lib/librxtxSerial-2.2pre1.so: /root/arduino-1.5.4/lib/librxtxSerial-2.2pre1.so: cannot open shared object file: No such file or directory thrown while loading gnu.io.RXTXCommDriver Exception in thread "main" java.lang.UnsatisfiedLinkError: /root/arduino-1.5.4/lib/librxtxSerial-2.2pre1.so: /root/arduino-1.5.4/lib/librxtxSerial-2.2pre1.so: cannot open shared object file: No such file or directory at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1750) at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1675) at java.lang.Runtime.loadLibrary0(Runtime.java:840) at java.lang.System.loadLibrary(System.java:1047) at gnu.io.CommPortIdentifier.<clinit>(CommPortIdentifier.java:123) at cc.arduino.packages.discoverers.SerialDiscovery.discovery(SerialDiscovery.java:53) at cc.arduino.packages.DiscoveryManager.discovery(DiscoveryManager.java:77) at processing.app.Editor.populatePortMenu(Editor.java:993) at processing.app.Editor.buildToolsMenu(Editor.java:720) at processing.app.Editor.buildMenuBar(Editor.java:489) at processing.app.Editor.<init>(Editor.java:217) at processing.app.Base.handleOpen(Base.java:840) at processing.app.Base.handleOpen(Base.java:805) at processing.app.Base.handleNew(Base.java:701) at processing.app.Base.<init>(Base.java:415) at processing.app.Base.main(Base.java:224)
With the Debian Wheezy Softfloat with LXDE posted by miousername here: http://www.udoo.org/forum/viewtopic.php?f=19&t=251 it should work. Give it a try.
thanks for the reply delba, i have been running on wheezy already. However, great news - after 3 nights of work, I managed to find the issue. I simply deleted the /root/arduino-1.5.4/lib/librxtxSerial-2.2pre1.so and replaced it with the systems usr/lib/jni/librxtxSerial-2.2pre1.so then I ran ./arduino and presto - it worked !! So thrilled that I've got wheezy on my udoo along with the 1.5.4 Arduino IDE. Now onto my next phase - see how both the sam and mx6 can manipulate the same gpio pin ;-)
Could you please help me with the lib? - the path /usr/lib/jni/librxtxSerial-2.2pre1.so doesn't exists so I have no jni directory.... Is there any dependancy? thx
It needs librxtx-java to be installed manually.... Code: sudo apt-get install librxtx-java The shame is that this IDE is not able to work with other arduino's as it offers only DUE boards
