Hi, I have a bolt V8 and it is not working. I had built an OS on the unit back in 2019 and was waiting to get metals case for it. It arrived yesterday and I seated the bolt. When I powered the unit on the bolt led lit on the box but when I pressed the power button nothing happened. I removed power from the bolt and there have been no led lighting on the unit. I removed all peripherals except memory I removed the unit from the case and tried to power on with the power microswitch, no success I bought a powersupply with the bolt. The supply lights with a green led. When I plug it into the bolt the led begins to flash on and off in a regular pattern. I just cant seem to get the unit to run at all Any help appreciated.
