Boot after powerfail
Discussion in 'UDOO BOLT' started by jorgy, May 3, 2020.
  1. jorgy
    jorgy UDOOer
    Sep 15, 2017
    Hello,
    I'm looking to turn my Udoo Bolt into a NAS and I was wondering if the 1.06RC or 1.07 BIOS updates have fixed the issue where the Bolt doesn't come back on a power outage. When the power goes out, I have to manually hit the power button in order for it to come back on, and this is definitely a deal breaker for turning it into a NAS. If someone has updated their BIOS could verify that this has been fixed, that would be great.
    Thank you,
    jorgy
    2,306
    578
    From the BIOS History (1.08 is the latest released) it looks like the issue was already fixed in 1.06:
    - added always ON Power Failure Resume Type;
    Why not just update and look (I have no Bolt)?
    1.08  [2020-04-23]
    - Label change
    - Changed default setup for Fan Thermal management
    - Corrected bug in temperature hysteresis (Was managed in tenth of grades)
    1.07.1  [2020-03-19]
    - Solved issue "board hang during boot from G3 state"
    - Added setup option to enable/disable 3 wire fan enhanched RPM measurement (Disabled by default)
    - Firmware 021
    1.06  [2020-01-20]
    - first official BIOS;
    - Realtek UEFI driver / PXE boot support added;
    - first MEC complete versions;
      - HWM (FAN/temperature/voltages);
      - port80 serial redirection;
      - completely tested MailBox mechanism.
      - enhanced setup and init;
    - known issues:
      - Linux video driver can hang after several Suspend to RAM/resume repeated
        operations (usually 25);
      - some nVME devices sporadically can cause boot hanging
  3. jorgy
    jorgy UDOOer
    Sep 15, 2017
  4. jorgy
    jorgy UDOOer
    Sep 15, 2017
    I updated my Bolt to 1.08 and can verify that it is NOT fixed with respect to turning back on after a power cut. It is running CentOS 8.1.1911, though that shouldn't matter, as this is a BIOS issue.
  5. waltervl
    2,306
    578
    Did you modify the power resume type in Bios?
    jorgy likes this.
  6. waltervl
    2,306
    578
    I meant the power failure resume type....
  7. jorgy
    jorgy UDOOer
    Sep 15, 2017
    Bingo! Thanks Waltervl, that was the trick. My Bolt now resumes properly after a power outage just as needed. Thanks again!
  8. rdslw
    rdslw UDOOer
    Apr 5, 2014
    38
    16
    Guys,
    can you post what are new defaults for fan control in 1.08 Bios?
    I would appreciate all fan settings (ac0/ac1 and others on fan control screen)
  9. waltervl
    2,306
    578
    Next time please ask your question in a new topic or a fan related topic as your question is completely off topic. But to answer it: look here https://www.udoo.org/docs-bolt/BIOS_UEFI_and_Tools/Fan_Settings.html
    rdslw likes this.
