Hello guys, I want to use the BLE Bluetooth Low Energy stack and create applications for it. I am using the UDOObuntu 2.1 Image on UDOO neo full I want to use Qt5.7 for creating the applications, because the precompiled Version 5.2.1 doesn't support BLE. So, after some research, I also found out, that i need to update my BlueZ Version to the most recent one because the older v4.x doens't really support BLE. So after I compiled and installed BlueZ 5.42, I need to configure, make and install Qt5.7. My question is, which configure parameters do I need to cross-compile Qt5.7 for the UDOO neo board? My actual configuration Looks like this: sudo ./configure -prefix /opt/qt5 -make libs -no-pch -no-opengl -device imx6 \ -device-option CROSS_COMPILE=/[...]/Qt5_Build/arm-linux-gnueabihf/bin/arm-linux-gnueabihf- \ -opengl es2 -qt-zlib -qt-libpng -qt-libjpeg -no-cups -gui -make examples -sysroot /path/to/mountpoint \ -no-gcc-sysroot -opensource -confirm-license -qreal float -v The configuration passes but the compilation leads to various errors, which i will add after another try. If anyone has a good tutorial or some tips, how to build Qt5.7 properly, please let me know.
Hi ! If you want to use qt5.7 with udoo card, the easyiest way is to use yocto (if you don't need a desktop like udoobuntu). See the first two post (sticky). To make a first test you can download the precompiled image (qt 5.6.2 that not include all qt modules) and after build your own ! For information i have an image for neo with qt 5.7 (full) with bluetooth working. If i have the time next week, i post it on the thread.
Thanks for your reply. I built Qt5.8 now and installed it on the UDOO Image. It all went so far so good but I cannot use the dbus to communicate with BlueZ, which I had upgraded to v5.42 before. First, I tried to discover some devices but the communication via dbus isn't working. After that, I tried to communicate directly with the dbus with the QT dbus module. This also didn't work. If I scan for Bluetooth devices with the command "hcitool lescan", i get a list of available Bluetooth devices. It would be great, if you can post your Image! And if you have any suggestions for my problem, please tell me Thanks in advance
Ok i will try to post it this week ... Also can you describe your procedure to build Qt5.8 on udoobuntu --> it could be interest some users ...
