Digital Arduino Pin Max Output
Discussion in 'UDOO X86' started by Manu Bedrossian, Oct 5, 2017.
  1. Manu Bedrossian
    Manu Bedrossian New Member
    Oct 5, 2017
    I'm a little confused on the documentation for the UDOO x86. For the arduino pinout information, it says that the digital I/O pins are 3.3 V, and 5 V compliant. What exactly does 'complaint' mean in this situation?
    My ultimate goal would be to use the digital pins to output 5 V to use for an LED.
    Any help would be much appreciated!
    Markus Laire likes this.
  2. YellowGTM
    YellowGTM Member
    Sep 21, 2017
    56
    I'm confused about this as well. My best guess is that, GPIO's that are designated as 3.3V have compliant trigger levels
    (logic low and logic high ) when interfacing with 5V devices.
    Here is a good link with an explanation: https://learn.sparkfun.com/tutorials/logic-levels/33-v-cmos-logic-levels
    As for driving an LED, be sure to add a series current limiting resistor that does not undercut the power capability of the
    pin you're using.
  3. Manu Bedrossian
    Oct 5, 2017
    Thanks for the link! That's a great graphical explanation. Also, thanks for the heads up about the current limiting resistors for LED's. I've chosen LED packages with built in resistors for this very reason.
  4. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    I've thought that 'compliant' means that in addition to high/low levels being appropriate for both 3.3V and 5V operation, pins can accept 5V input without damage. (But output is still always 3.3V)
    It would be nice to have exact definition of 'compliant'.
  5. ccs_hello
    536
    194
    Arduino 101 is native 3.3V operation.
    Output pins follow that rule. 0V for low and close to 3.3V for logical high.
    5V tolerant is for I/O pin used in input mode.
