Does udoo_quad_revC_yocto_09072013.img work ? I`ve downloaded it and unzipped the image without fault , but tried to write in to 2 sd card with the same result. Code: U-Boot 2009.08-secoimx6dq_m975_1GB_LV_2013061540 (Jun 21 2013 - 15:38:38) CPU: Freescale i.MX 6 family 0.0V at 792 MHz Temperature: 26 C, calibration data 0x5844f769 mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 264000000Hz emi_slow clock: 29333333Hz ddr clock : 528000000Hz usdhc1 clock : 200000000Hz usdhc2 clock : 200000000Hz usdhc3 clock : 200000000Hz usdhc4 clock : 200000000Hz nfc clock : 24000000Hz Board: MX6Q-SECO_Q7:[ POR ] Boot Device: NOR I2C: ready DRAM: 1 GB MMC: FSL_USDHC: 0,FSL_ESDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:c0:08:88:a2:bc FEC0 [PRIME] Hit any key to stop autoboot: 3 It keeps looping .. and there is no 3-2-1
Yocto has some issues we still trying to solve but since we're focusing on different distros this fix could take a while
