I followed the instructions to install Arduino IDE in an external computer, after connecting Neo to the USB and trying to upload the Blink sketch I get this error: Arduino:1.6.7 (Mac OS X), Scheda:"UDOO Neo (Cortex M4)" ATTENZIONE: La categoria '' della libreria SPI non è valida. La imposto a 'Uncategorized' ATTENZIONE: La categoria '' della libreria Wire non è valida. La imposto a 'Uncategorized' Attenzione: platform.txt del core 'UDOO NEO (iMX6 SoloX)' contiene la stringa deprecata recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}" convertita automaticamente in recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Verifica la disponibilità di un aggiornamento di questo core. cc1plus: error: to generate dependencies you must specify either -M or -MM exit status 1 Errore durante la compilazione Questo report potrebbe essere più ricco di informazioni con "Mostra un output dettagliato durante la compilazione" abilitato in "File > Impostazioni" What does it mean? Thank you
According to the neo docs you have tot install version 1.6.5. it looks like you installed 1.6.7. I already read other issues (or the same) here on the forum when 1.6.7 was installed.
Oh okay, I supposed it was OK to install a newer version, will I find it on arduino.cc as well or do I have to find it somewhere else? Inviato dal mio iPhone utilizzando Tapatalk
Ok thanks. I suggest for Udoo guys to add a line to the documentation specifying that the last version of arduino IDE won't work, otherwise one may think the guide is simply a little bit outdated Inviato dal mio iPhone utilizzando Tapatalk
I've followed your suggestion and added a line on the page about "Arduino programming from internal IDE". (This warning was already present, but in the page "Use as an Arduino"; as you said, the clearer it is the better)
