GPIO through /sys/class
Discussion in 'UDOO NEO' started by major7, Nov 17, 2015.
  1. major7
    major7 New Member
    Nov 20, 2014
    Hi, in the docs it states that you can access GPIO ports through their numbers in
    /sys/class/gpio/gpio<pinnr>
    if I look do ls /sys/class/gpio/ i'm only seeing gpiochip[0 32 64 96 128 160 192]
    How does these relate to the gpio pins?
    Is this still work in progress?
  2. Andrea Rovai
  3. major7
    major7 New Member
    Nov 20, 2014
    I've read and done the export thing but the ports didn't show up
    after I did some more investigations it seems it doesn't work with sudo
    after becoming root it works like stated in the documentation
    which is less then ideal, as i don't want my application to run as root
    but ii did unblock me, thanks
  4. Andrea Rovai
    You should create a rule under
    cat /etc/udev/rules.d/10-imx.rules
    to give these files the permissions of the "udooer" user.
    Try to add these two lines at the bottom:
    SUBSYSTEM=="gpio", ACTION=="add", PROGRAM="/bin/sh -c 'chown -R root:ugpio /sys%p'"
    SUBSYSTEM=="gpio", ACTION=="add", PROGRAM="/bin/sh -c 'chmod -R g+rw /sys%p'"
    add the user "udooer" at the group ugpio
  5. necromancer
    necromancer New Member
    Nov 10, 2015
    26
    I followed the steps you mentioned, but i still cannot run run export without sudo.
  6. Andrea Rovai
    Dear Necromancer,
    to access GPIO you can use this library made by @Julien.
    Tell us if it works for you.
    Julien likes this.
  7. Jarryd Son
    Jarryd Son New Member
    Nov 24, 2015
    I have the same problem. I can only use something like sudo sh -c "echo ..." to do anything with the GPIO's or I have to be logged in as root. I tried appending those extra lines but nothing changed.
  8. Xykon
    Xykon Member
    Nov 1, 2013
    64
    20
    First off make sure you create the group ugpio and add it to the udooer user:
    sudo groupadd -r ugpio
    sudo usermod -a -G ugpio udooer
    When I added the lines mentioned above I could see that the gpios were available for the ugpio group but not /sys/class/gpio/export
    So I added another two lines to the udev file:
    SUBSYSTEM=="gpio", ACTION=="add", PROGRAM="/bin/sh -c 'chown -R root:ugpio /sys/class/gpio/export'"
    SUBSYSTEM=="gpio", ACTION=="add", PROGRAM="/bin/sh -c 'chmod -R g+w /sys/class/gpio/export'"
    Now I can do as user udooer:
    udooer@udooneo:~$ echo 25 > /sys/class/gpio/export
    udooer@udooneo:~$ echo out > /sys/class/gpio/gpio25/direction
    udooer@udooneo:~$ echo 1 > /sys/class/gpio/gpio25/value
    And the LED I connected on header J6 port 24 turns on.
    Julien, Andrea Rovai and Jarryd Son like this.
  9. Jarryd Son
    Nov 24, 2015
    I have added everything that you said and it still doesn't work. It keeps saying permission denied.
  10. Jarryd Son
    Nov 24, 2015
    Nevermind. I forgot to reboot/logout for the changes to take effect. It's working now. Thanks Xykon :)
    Andrea Rovai likes this.
  11. Julien
    Julien New Member
    Nov 8, 2015
    This is an awesome answer. Do you care if I copy it to a Gist?
    Xykon likes this.
  12. Julien
    Julien New Member
    Nov 8, 2015
    Thanks a lot for the mention, unfortunately my library also needs root privileges for changing values :(
  13. Xykon
    Xykon Member
    Nov 1, 2013
    64
    20
    Not at all, everything I post here should be considered "public domain". The -R after the chown and chmod command isn't necessary, as it's only one file (-R is for recursive subdirectories). So this should work too, although I haven't tested it personally as I've got a very busy work week:
    SUBSYSTEM=="gpio", ACTION=="add", PROGRAM="/bin/sh -c 'chown root:ugpio /sys/class/gpio/export'"
    SUBSYSTEM=="gpio", ACTION=="add", PROGRAM="/bin/sh -c 'chmod g+w /sys/class/gpio/export'"
    You might also want to add that a reboot should be performed after these changes... (you can get around that if you know what you're doing but I don't have time to validate the exact steps right now)
    Julien and Andrea Rovai like this.
  14. Julien
    Julien New Member
    Nov 8, 2015
    Alright, thanks!
  15. TheHat
    TheHat New Member
    Dec 16, 2015
    I updated /etc/udev/rules.d/10-imx.rules by adding the following lines to the very end of the file:
    I also did:
    I then re-booted
    I can change and see the direction change by:
    echo in > /sys/class/gpio/gpio25/direction
    cat /sys/class/gpio/gpio25/direction
    but I CAN NOT change the output value, it's always a 0 when I do the following
    cat /sys/class/gpio/gpio25/value
    I have tried below which didn't work either.
    sudo echo 1 > /sys/class/gpio/gpio25/value
    What am I missing?
    Thanks for any help.
  16. necromancer
    Nov 10, 2015
    26
    How do you know that the value is always 0? Do you have an LED connected? does the LED turn on and off?
    Did you try to read the value by
    if you did, then the document also says the following;
    So try putting an LED in that pin to see the led turn on and off
  17. TheHat
    TheHat New Member
    Dec 16, 2015
    Thanks for the clarifications... It sounds like the GPIO it's self is not a true bi-directional pin if "read the value is not guaranteed that the kernel value is coherent with the voltage found on the external pinout."
    I am able to see the output change state using a DVM, now. Thanks again.
  18. Andrea Rovai
    This happens when the GPIO is setted in output and you want to read in, as stated in the docs.
  19. waltervl
    2,260
    564
    Just to inform you that this update is not needed anymore with the just released Udoobuntu 2 RC2! GPIO is exported at startup and no need for sudo rights to set value!
  20. Julien
    Julien New Member
    Nov 8, 2015
    That's great, guess it's time for me to update the little fella. How did you learn about the RC2? I haven't received any email
