gpio0 on UDOObuntu 2.0
Discussion in 'Linux Ubuntu' started by Nicola 94, May 22, 2016.
  1. Nicola 94
    Nicola 94 New Member
    May 22, 2016
    Hi!
    The code:
    echo out > /sys/class/gpio/gpio0/direction
    echo 0 > /sys/class/gpio/gpio0/value
    is not working on UDOO quad running UDOObuntu 2.0.
    How can I reset the SAM3X from the MX6?
    Were did you find this instruction in the docs?
  3. Nicola 94
    May 22, 2016
  4. waltervl
  5. waltervl
    Well just checked on my udoo Quad with rc2: Does not work for gpio0. This gpio is used by bossac to reset the sam3x.
    It works for the normal (Arduino) pins with /gpio/pinxx/value
    It lookslike in udoobuntu 2 something has changed.
  6. Nicola 94
    May 22, 2016
    Thank you for confirming this.
    Are there any ways to handle the gpio0 pin in udoobuntu 2?
  7. Andrea Rovai
  8. waltervl
    Well, I think I tested it with Udoobuntu 2, not RC2. At he time I posted this (2016-05-25) it was already 2 (Release Date: 2016-05-11).
    I only found out recently that Quad/Dual are already on a final release of Udoobuntu (unlike the Neo)
  9. Andrea Rovai
    @waltervl, I know it was already available, but I asked because in your previous message you were speaking about RC2
  10. waltervl
    to clarify: I thought I tested it with RC2 but realised later that it was 2 as I installed my Quad after the release date of 2.
  11. ektor5
    Jul 1, 2013
    97
    48
  12. waltervl
    So if I read this correctly
    echo erase > /dev/udoo_ard
    should erase/reset the SAM3X? I did not try it yet......
    or use
    bossac --reset ???
  13. ektor5
    Jul 1, 2013
    97
    48
    Actually, no.
    You need to fopen the device, and then fput "erase".
    I successfully managed to erase/reset with the following command:
    bossac-udoo --reset -p /dev/ttymxc3
    And in the dmesg you'll probably see:
    [  49.878470] [bossac] UDOO ERASE and RESET on Sam3x started.
    [  50.313519] [bossac] UDOO ERASE and RESET on Sam3x EXECUTED.
    [  50.313863] [bossac] UDOO ERASE and RESET on Sam3x started.
    [  50.753517] [bossac] UDOO ERASE and RESET on Sam3x EXECUTED.
    I don't think that is possible to reset the Sam3x only. You also need to erase the flash memory.
    Ek5
    Andrea Rovai and waltervl like this.
