Gstreamer crashes udoo when trying to stream camera module
Discussion in 'Accessories' started by nonlinearmind, Sep 10, 2014.
  1. nonlinearmind
    nonlinearmind New Member
    Aug 9, 2014
    I'm trying to get gstreamer to stream the camera module to a crtmpserver video server. I'm trying the following pipeline:
    gst-launch -q mfw_v4lsrc ! x264enc byte-stream=true  ! flvmux ! tcpclientsink host=192.168.1.20 port=6666
    It ends up freezing the UDOO board, requiring a restart.
    However, the following test works:
    gst-launch -q videotestsrc ! x264enc byte-stream=true  ! flvmux   ! tcpclientsink host=192.168.1.20 port=6666
    What do I need to change in my pipeline?
  2. toussa
    toussa New Member
    Aug 29, 2014
  3. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Try with
    gst-launch-0.10 -q mfw_v4lsrc ! x264enc byte-stream=true  ! flvmux ! tcpclientsink host=192.168.1.20 port=6666
  4. nonlinearmind
    Aug 9, 2014
    Re: Gstreamer crashes udoo when trying to stream camera modu
    That's the same pipeline I tried.
  5. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Nope,
    you tried:
    gst-launch
    I suggested:
    gst-launch-0.10
    This is because in UDOOBuntu we have a different version of gstreamer, optimized for armhf... This is why you command is failing... We'll upgrade the doc accordingly.. Let me know!
  6. nonlinearmind
    Aug 9, 2014
    With either, I get:
    MFW_GST_V4LSRC_PLUGIN 3.0.8 build on Nov 19 2013 12:57:36.
    then udoo freezes.
    Is there a way to make it work using ffmpeg? I've tried using /dev/video0, but get an error.
  7. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
