how to get /dev/ttyACMx?
Discussion in 'Linux Ubuntu' started by jeffKuo, Jan 16, 2014.
  1. jeffKuo
    jeffKuo New Member
    Jan 5, 2014
    Hi
    I found that there was no ttyACM in /dev on UDOO with ubuntu12.04.
    How to get this driver?
    I already try modprobe cdc_acm.
    doesn't work.
    The reason I want this driver is I want to use HOKUYO Laser sensor on UDOO.
    I google it and find this website.
    http://www.hokuyo-aut.jp/02sensor/07scanner/download/urg_programs_en/devel_lin_page.html
    I already follow it to install SDL and BOOST
    After that, it says HOKUYO should be recognized as /dev/ttyACMx. (by using dmesg to see the message)
    http://www.hokuyo-aut.jp/02sensor/07scanner/download/urg_programs_en/serial_lin_page.html
    However, i always get this information
    [ 767.489049] usb 2-1.1.2: USB disconnect, device number 9
    [ 767.741565] usb 2-1.1.2: new full speed USB device number 10 using fsl-ehci
    the number 10 is my laser sensor.
    or anyother way to control HOKUYO by UDOO?
  2. chrizdee
    chrizdee New Member
    Jan 4, 2014
  3. danielespitia
    danielespitia New Member
    Oct 18, 2013
    Hi I'm using the Hokuyo laser scanner with the UDOO using ROS groovy and hokuyo_node.
    [​IMG]
    I'm using the UDOObuntu 1.0 image
    Just install ROS groovy using this:
    http://wiki.ros.org/groovy/Installation/UbuntuARM
    And install the hokuyo:
    sudo apt-get install ros-groovy-laser*
    Then:
    sudo chmod a+rw /dev/ttyACM0
    rosparam set hokuyo_node/calibrate_time false
    rosparam set hokuyo_node/port /dev/ttyACM0
    rosrun hokuyo_node hokuyo_node
    The hokuyo data will be published in the topic /scan
