How to get WiFi & Bluetooth working in Ubuntu
Discussion in 'UDOO NEO' started by agitprop, Nov 5, 2015.
  1. agitprop
    agitprop New Member
    Nov 5, 2015
    I'm a novice with MCUs, but have some UNIX/LINUX experience. Just got my Neo and installed Ubuntu on it just fine. I VNC'd into the Neo, which also worked fine.
    BUT. . . neither the Network Connections nor the Bluetooth Manager system preference seem to talk to the board. The former has all tabs and fields greyed out, and the latter just doesn't bother to open at all.
    What am I missing? Do I need to tweak some stuff via the Terminal, to turn on the Wifi/Bluetooth module?3
  2. sanyasi rao
    sanyasi rao New Member
    Nov 14, 2015
    Hi I have the same issue.. I have tried editing the /etc/network/interface file to have a statric ip . but that did not work either
  3. Marco Schiff
    Marco Schiff New Member
    Nov 5, 2015
    20
    you can not change the network settings if you are connected to the card via the Internet. via vnc can not touch the network settings - you can change them through micro hdmi
    Inviato dal mio iPhone utilizzando Tapatalk
  4. Andrea Rovai
    sudo nm-connection-editor
