I need a system ready for a 3D printer
Discussion in 'Linux Ubuntu' started by ProCoPrint3D, Dec 5, 2014.
  1. ProCoPrint3D
    ProCoPrint3D New Member
    Nov 27, 2014
    22
    I bought the quad, I need a ready system image with software Slic3r or Printrun or Repetier Host.
    Has anyone tried it?
    I install the software but do not want to show in the window. Do not know much about Linux, I build the instructions and is installed but not working.
    Thank you for your help
  2. delba
    1,064
    I didn't try Slic3r with UDOO yet. :(
  3. ProCoPrint3D
    Nov 27, 2014
    22
    Does anyone have a complete system for the 3D printer
  4. ProCoPrint3D
    Nov 27, 2014
    22
    Unfortunately, I regret that issued 250 Euros down the drain because there is no support for 3D printers.
    Plate just to control your printer is not worth anything without a graphic panel.
    For people who want to control your printer would also recommend the 32-bit Arduino Due to the support of the software.
  5. ProCoPrint3D
    Nov 27, 2014
    22
  6. ProCoPrint3D
    Nov 27, 2014
    22
    How to run the Printrun on UDOO?
  7. ProCoPrint3D
    Nov 27, 2014
    22
  8. ProCoPrint3D
    Nov 27, 2014
    22
  9. delba
    1,064
    ProCoPrint3D, any luck with Printrun?
  10. ProCoPrint3D
    Nov 27, 2014
    22
    3D printer ProCoPrint3D / ME slowly begins to talk with the new Software and Hardware
    [​IMG]
  11. delba
    1,064
    Woah awesome!!! :O
  12. ProCoPrint3D
    Nov 27, 2014
    22
    I get the same message as I want to run the program
    debian@udoo-debian-hfp:~/Printrun$ python2 pronterface.py
    WARNING:root:Memory-efficient GCoder implementation unavailable: No module named gcoder_line
    WARNING:root:Could not setup DBus for sleep inhibition: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
    Unable to access the X Display, is $DISPLAY set properly?
  13. ProCoPrint3D
    Nov 27, 2014
    22
    Errors errors and errors again,
    debian@udoo-debian-hfp:~/Printrun$ python2 pronsole.py
    WARNING:root:Could not setup DBus for sleep inhibition: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.ScreenSaver was not provided by any .service files
    Traceback (most recent call last):
      File "pronsole.py", line 26, in <module>
        interp.parse_cmdline(sys.argv[1:])
      File "/home/debian/Printrun/printrun/pronsole.py", line 711, in parse_cmdline
        self.process_cmdline_arguments(args)
      File "/home/debian/Printrun/printrun/pronsole.py", line 698, in process_cmdline_arguments
        self.update_rpc_server(None, self.settings.rpc_server)
      File "/home/debian/Printrun/printrun/pronsole.py", line 670, in update_rpc_server
        self.rpc_server = ProntRPC(self)
      File "/home/debian/Printrun/printrun/rpc.py", line 37, in __init__
        logRequests = False)
      File "/usr/lib/python2.7/SimpleXMLRPCServer.py", line 593, in __init__
        SocketServer.TCPServer.__init__(self, addr, requestHandler, bind_and_activate)
      File "/usr/lib/python2.7/SocketServer.py", line 419, in __init__
        self.server_bind()
      File "/usr/lib/python2.7/SocketServer.py", line 430, in server_bind
        self.socket.bind(self.server_address)
      File "/usr/lib/python2.7/socket.py", line 224, in meth
        return getattr(self._sock,name)(*args)
    socket.error: [Errno 99] Cannot assign requested address
  14. ProCoPrint3D
    Nov 27, 2014
    22
    Fedora
    Printrun is in official Fedora repositories starting with Fedora 17.
    sudo yum install printrun # for the whole package, or:
    sudo yum install pronsole # or plater or pronterface
    the rest system is shit for Printrun
    Please make fedora image SD
  15. ProCoPrint3D
    Nov 27, 2014
    22
    Can someone make an image to the SD card ArchLinux for Udoo Quad or Fedora more 17?
    I ask because I do not have the strength to try to test and combine.
    I'm doing a CNC machine and I want to insert the control board there Udoo so far without success.
    I must have Printrun control program, this program is in ArchLinux. Please help.
  16. ProCoPrint3D
    Nov 27, 2014
    22
    setenv sataroot "/dev/sda1"
    setenv satadev 0
    setenv satapart 1
    setenv loaduimagesata 'ext2load sata ${satadev}:${satapart} ${loadaddr} ${uimage}'
    setenv sataargs 'setenv bootargs console=${console},${baudrate} root=${sataroot} ${hdmi_patch} fbmem=24M video=mxcfb0:dev=hdmi,1920x1200M@60,bpp=32'
    setenv sataboot 'echo Booting from sata ...; run sataargs ; bootm'
    setenv bootcmd 'sata dev ${satadev}; run loaduimagesata; run sataboot;'
    saveenv
    reset
  17. delba
    1,064
    Answered here: post11323.html#p11323
