HI all, I've installed scilab on udoo using sudo apt-get install scilab which installs version 5.3.3. How can I upgrade scilab to the latest stable version 5.5.1 or alternatively reinstall latest version. Any help is very much welcome. Thanks.
You have 2 options: - Compile scilab on your own: http://wiki.scilab.org/Compiling%20Scil ... nux%20Unix which i suggest you. - or download the binary (be aware that you should take care of the dependencies): https://packages.debian.org/jessie/scilab
HI there - thx for your reply. so I've tried to compile Scilab from the source file aswell as the prerequirements. To deal with the dependancies, after using sudo apt-get update I tried sudo apt-get build-dep scilab. So far so good , then installed gfortran, java jdk 1.8 (as described in Udoo FAQ). Then added the line deb-src http://ports.ubuntu.com/ precise main restricted universe multiverse in /etc/apt/sources.list sudo apt-get update again now ./configure wants to see jogl installed. Any ideas here - can't get it to work. as you can see I'm a complete novice in linux&udoo. Thanks.
HI there, When I try to compile from scilab from source I get to the libjogl (dependancy) problem. Installing the binary and adding: deb http://ftp.de.debian.org/debian jessie main to /etc/apt/sources.list and run sudo apt-get update crashes the OS and I need to reinstall it. Is there no other way perhabs to update the lubuntu software center so that scilab 5.5.X not 5.5.3 lists as an option? Thanks for any help !
hi, here's the error I get when trying to compile scilab on the UDOO from source: apt-get build-dep scilab for the dependancies gives not error. Trying ./configure it hangs on the following error: libjogl: LIbrary missing (cannot find symbol gLTextParameterf). Check if libjogl - C/Java (JNI) interface for JOGL2 - or libGL (OpenGl library) are installed and if the version is correct. Note you may have to update etc/librarypath.xml to provide path to JNI librarier. How can I install JOGL2 or libGL and update the librarypath.xml correctly? THANK YOU!
I've tried the synaptic package manager before I find libjogl2-java and try to install it: error: could not apply changes . fix broken packages first. Edit->Fix broken packages and it reads: unable to correct problem you have held broken packages. unable to correct dependencies:Error , pkgProblemResolver: Resolve generated breaks, this may be cause by held packages. Then tried: apt-get install -f apt-get clean apt-get auto clean apt-get update apt-get upgrade apt-get dist-upgrade Reads: 0 upgraded, newly installed, remove and not upgraded Then: sudo apt-get install libjogl2-java error: Some packages could not be installed.... The following packages have umnet dependencies: libjogl2-java: depends libjogl2-jni but is not installable E: unable to correct problems, you have held broken packages sudo aptitude install libjogl2-java -> same error
