Keep arduino 101 running while braswell or OS is off
Discussion in 'UDOO X86' started by spinxz, Apr 23, 2017.
  1. spinxz
    spinxz New Member
    Dec 26, 2013
    Hi
    When I load the Arduino Blink example onto the 101 it works fine until I shutdown the operating system. Turning off the OS/Braswell also stops the Arduino 101 from running (also for suspend to ram/disk).
    How can I keep the sketch running while the system is off or sleeps? This would be necessary in case I want to wake up the OS from the Arduino...
  2. x1800MODMY360x
    x1800MODMY360x Member
    Mar 29, 2017
    55
    It must be a setting in the bios.
  3. ccs_hello
    536
    194
    Per current schematics, Intel Braswell SoC has a (software driven) signal output: Curie_Reset#.
    This will lead to a small hardware block performing the actual Curie RESET action (same behavior as pushing the Curie Reset button.)
    There is also another signal Curie_Pwr_EN coming out of the STM32 microcontroller which can turn on or off the power supplies (3v3 and 5C) of the Arduino 101.
    ccs_hello
  4. waltervl
  5. spinxz
    spinxz New Member
    Dec 26, 2013
    I agree that it should be in the bios. As mentioned it could be related to the
    Curie Reset on PowerON bios setting which is needed because of the 101 firmware bug. I wonder why there is no setting to independently control when the Arduino is running...
  6. waltervl
    You have to put OS/Braswell to sleep to S3/S4/S5 sleep state as mentioned in the docs. Arduino 101 should keep running in those states. Then you can wake the Braswell up again from Arduino.
    But only if you set the power options in bios/UEFI right as mentioned in the documentation.
    ccs_hello likes this.
  7. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    91
    diglo and waltervl like this.
