Hi all, I'm having difficulty getting the UDOO 15" LCD Touch Panel to work with UDOO QUAD board. It appears the QUAD board can't detect the LCD panel. Uboot console indicates no LCD panel detected. Console log below. Yes, I double checked connectors are fully seated. I confirmed DC supply voltages are present on the UDOO board side of interconnecting cable. The other side at the LCD panel is a bit dicey to probe... I'm using the latest Ubunto image (UDOObuntu_quad_v1.0.img, U-Boot 2013.10-rc3) from UDOO web site. I might have to return the 15" LCD panel to mothership, UDOrg. Any debug tip is appreciated. Additional info: UDOO QUAD board works fine with HDMI display with UDOObunto and Android Jellybean. Getting the board to work with the 15" LVDS panel has not been a plug-n-play experience Regards, John C. ***These are my comments***************** boot into Ubuntoo 1.0 Linux using HDMI display changed default to display 15" LCD powered off inserted LVDS high speed conn, and touch USB powered on console out follows: **************************************** U-Boot 2013.10-rc3 (Jan 20 2014 - 13:33:34) CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR Board: UDOO DRAM: 1 GiB MMC: FSL_SDHC: 0 No panel detected: default to LDB-WVGA Display: LDB-WVGA (800x480) In: serial Out: serial Err: serial Net: using phy at 6 FEC [PRIME] Hit any key to stop autoboot: 0 UDOO board => UDOO board => printenv baudrate=115200 boot=echo No boot source specified bootargs_base=setenv bootargs console=ttymxc0,115200 bootargs_nfs=setenv bootargs $(bootargs) root=/dev/nfs ip=dhcp nfsroot=$(serverip):$(nfsrootfs),v3,tcp bootcmd=run ${src}boot; run sataboot; run mmcboot; run netboot; bootcmd_net=run bootargs_base bootargs_mtd bootargs_nfs; tftpboot 0x81000000 uImage-mx31; bootm bootdelay=5 console=ttymxc1 ethact=FEC ethaddr=00:c0:08:88:20:43 ethprime=FEC get_cmd=ntp ipaddr=dhcp loadaddr=0x12000000 memory=fbmem=24M gpu_reserved=128M mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} ${hdmi_patch} ${memory} ${video} mmcboot=if mmc rescan; then echo Booting from mmc ...; run mmcloaduimage; run mmcargs; bootm; else mmc boot failed; fi mmcdev=0 mmcloaduimage=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage} mmcpart=1 mmcroot=/dev/mmcblk0p1 rootwait rw netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ${hdmi_patch} ${memory} ${video} ip=${ipaddr} nfsroot=${serverip}:${nfsroot},v3,tcp netboot=echo Booting from net ...; run netargs; ${get_cmd} ${uimage}; bootm nfsroot=/src/nfs4/ prg_uboot=tftpboot 0x81000000 u-boot-with-spl.bin; nand erase 0x0 0x40000; nand write 0x81000000 0x0 0x40000 sataargs=setenv bootargs console=${console},${baudrate} root=${sataroot} ${hdmi_patch} ${memory} ${video} sataboot=if sata init; then echo Booting from sata ...; run sataloaduimage; run sataargs; bootm; else sata boot failed; fi satadev=0 sataloaduimage=ext2load sata ${satadev}:${satapart} ${loadaddr} ${uimage} satapart=1 sataroot=/dev/sda1 rootwait rw serverip=192.168.1.1 splashpos=m,m src=sata uimage=/boot/uImage video=video=mxcfb0:dev=ldb,1366x768M@60,if=RGB24,bpp=32
mmm weird, try to open a ticket in our Customer Care explaining your problem: http://www.udoo.org/customer-care/
Hello UDOO Team, The panel had been confirmed dead. Trying another panel works (after resetting display env var per UDOO tech support). UDOO customer support had sent a replacement panel. UDOO support on this LCD issue is appreciated. As a gesture of thanks and vote of confidence in UDOO, my organization had placed orders for more LCD panels, UDOO boards, and accessories. Regards, John C. 2014-11-24
johnchiu that's a great news! Our main task is the satisfaction of our UDOOers. Every time you need help don't hesitate to write here or contact us. Best regards.
