LVDS 7" set up problem
Discussion in 'Troubleshooting' started by Lorenzo.MdpTech, Oct 28, 2016.
  1. Lorenzo.MdpTech
    Lorenzo.MdpTech New Member
    Oct 25, 2016
    Hello,
    i've just bought some LVDS 7" for Quad (which is my board), i've followed the istructions for setting them up, but nothing shows up on the screen.
    So, first of all I've established the connection between my pc and the board with putty (Windows), then I physically connect the LVDS, I insert the micro sd with android flashed inside (everything works if i try with the HDMI so i think it isn't an android problem), I plug the current (original UDOO power supply) and finally I stop the normal boot procedure from putty console.
    Here what the console says:
    __________________________________________________
    CPU: Freescale i.MX6Q rev1.2 at 792 MHz
    CPU: Temperature 40 C
    Reset cause: POR
    Board: UDOO Quad
    Watchdog enabled
    DRAM: 1 GiB
    MMC: FSL_SDHC: 0
    *** Warning - bad CRC, using default environment
    No panel detected: default to HDMI
    Display: HDMI (1280x720)
    In: serial
    Out: serial
    Err: serial
    check_and_clean: reg 0, flag_set 0
    Fastboot: Normal
    flash target is MMC:0
    Net: using phy at 6
    FEC [PRIME]
    Normal Boot
    Hit any key to stop autoboot: 0
    I noticed that in the video tutorial from UDOO the screen has a white light in the moment he plugs the power, mine doesn't do anything.
    After that I've set the output to the LVDS following the commands provided by Udoo in the LVDS setup page
    I write saveenv, and then boot.
    From the putty console I can see that the device can't find the LVDS and if I manually reboot from the button the watchdog restart continuosly the board.
    I have to flash again the SD to reset the settings and then it starts to work again with the HDMI as it normally does.
    2,236
    561
    Udoobuntu or Android? Which version?
    Edit: I read Android. What version? Personally I cannot help but perhaps others with Android can give you tips
    Lorenzo.MdpTech likes this.
  3. Lorenzo.MdpTech
    Oct 25, 2016
    Android 6.0.1 marshmallow, for Udoo Quad, the one available at this link.
    It worked with the HDMI computer screen
  4. Andrea Rovai
  5. Lorenzo.MdpTech
    Oct 25, 2016
    It works, i wasted a lot of time trying to set the output throught serial and the answer was so easy :eek:
    Thanks a lot!
    Andrea Rovai and waltervl like this.
