M.2 compatibility
Discussion in 'UDOO X86' started by DUNKEL, Jun 19, 2018.
  1. DUNKEL
    DUNKEL New Member
    Jun 19, 2018
    Buenas, quería preguntar por un ssd m.2, a la hora de comprar, vale cualquiera? o tengo que ver que cumpla o no cumpla algo?, disculpar soy novato, gracias
    Hi, I wanted to ask for a ssd m.2, when buying, is it worth any? or do I have to see that it fulfills or does not comply with something ?, sorry I am a novice, thank you
    2,295
    565
  3. DUNKEL
    DUNKEL New Member
    Jun 19, 2018
    Gracias, otra pregunta, puedo formatear (eliminar ) la tarjeta eMMC interna sin problemas ? o perderia informacion? lo que me refiero es si la bios de la placa va en memoria a parte o en esta, gracias y disculpa las molestias
    Thanks, another question, can I format (delete) the internal eMMC card without problems? or lose information? What I mean is if the bios of the plate goes in memory to part or in this, thank you and apologize for the inconvenience
  4. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    91
    You can format eMMC safety, BIOS doesn't use it (BIOS is saved to separate place you can't access directly).
    eMMC might contain some test files from factory testing, but those are safe to delete.
  5. DUNKEL
    DUNKEL New Member
    Jun 19, 2018
    Gracias
    Thank you
